Kostamojen Posted September 7, 2005 Share Posted September 7, 2005 Ok, so I gave it another shot with the Junkyard carb... Failed badly, I screwed up the timing thats for sure. Here are the sheets from it: As you can see, its still not idling right, and its still dumping alot of gas... Plus I guess I have to get that lame heater hose on there too. I wonder whats wrong this time, sheesh... I'm going to have to give up soon. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 8, 2005 Author Share Posted September 8, 2005 How would a bad choke cause the car to act? Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 8, 2005 Share Posted September 8, 2005 THat sucks. Your a gross polluter. I'd say wait 3 years and then it will be a classic. -Brian Link to comment Share on other sites More sharing options...
rallyruss Posted September 8, 2005 Share Posted September 8, 2005 that really does not look too bad. I think you can get it to pass if you try. the timing alone will be a big factor there. Link to comment Share on other sites More sharing options...
cricket Posted September 8, 2005 Share Posted September 8, 2005 Kostamojen said: How would a bad choke cause the car to act? It would run rich, very rich. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 9, 2005 Author Share Posted September 9, 2005 Alright, im going to try one more combination with the carb, then put the heater hose on, try to set the timing right, then wait for the fuel cap... Link to comment Share on other sites More sharing options...
MudisFun Posted September 9, 2005 Share Posted September 9, 2005 Better luck next time! Link to comment Share on other sites More sharing options...
Kostamojen Posted September 10, 2005 Author Share Posted September 10, 2005 Well I give up. The car is spewing white smoke now. I put in the working choke, then reset the timing according to the service manual (disconnect the distributor advance/retard, and the vacume advance) set it to 850rpms with 8% of timing, then pluged everything back in and disconnected that recirculation silved suction thingy from the air cleaner and pluged it and set the idle for 850 rpms. It idles great, seems to be working fine, but ya its spewing nasty white smoke when you rev it hard and let off the gas... I really dont have any ability to do anything else with it. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 10, 2005 Author Share Posted September 10, 2005 Also, I'm getting alot of oil from around the PCV valve now... Link to comment Share on other sites More sharing options...
Seahag1978 Posted September 10, 2005 Share Posted September 10, 2005 Chain of events. Ok, the carb is running right? Idle is there and timing right? All seems well. Smoke. Much smoke. Enough to gag a maggot? Do a compression test. Sounds like what mine did. Seems once I GOT proper fuel, spark, we found a cylinder was borked. Got a "new" engine in... all is well. Walla... daily driver! I HOPE I'm wrong! Best of luck! Mary Link to comment Share on other sites More sharing options...
Kostamojen Posted September 10, 2005 Author Share Posted September 10, 2005 If it needs an engine, the car is going up for sale The odd part was how it wasnt spewing as much smoke with the untouched junkyard carb, so I dont quite think its the engine itself... Link to comment Share on other sites More sharing options...
Seahag1978 Posted September 10, 2005 Share Posted September 10, 2005 The key here was once it gets everything it needs the engine problem reared its ugly head. Mine never smoked until it was running on its own, up to operating temp. Took the oil out... watery and smelled like gas. Big time. An engine is cheap. Not impossibly hard to change out either. Do the compression test. It'll rule that out. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 10, 2005 Author Share Posted September 10, 2005 Well since I cant do anything with the motor right now, I decided i'd primer the roof, lol! pic: http://community.webshots.com/photo/166896604/447619841xRpIZd Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 11, 2005 Share Posted September 11, 2005 White smoke is coolant. You need to make sure, when your swapping carbs, that you are using a new carburator gasket every time. If you do not, coolant will get from the water passage into the intake and that would cause the problem you are having right now. -Brian Link to comment Share on other sites More sharing options...
subie94 Posted September 11, 2005 Share Posted September 11, 2005 TheSubaruJunkie said: White smoke is coolant. You need to make sure, when your swapping carbs, that you are using a new carburator gasket every time. -Brian i agree. one time i had to rebuild a carb,now granted i used new gaskets but did clean the surface all the way.once the carb was back on the engine i'd get a whistle while it was running.i'd give it gas an whistle would stop.this shows that the smallest thing could cause a problem. Link to comment Share on other sites More sharing options...
Seahag1978 Posted September 11, 2005 Share Posted September 11, 2005 K-man, How does the exhaust smell? Get right down on it... if it smells like a toasted marshmallow... coolant is just leaking by, if it smells like strong, normal exhaust then my guess is engine. Can you get a little oil out? Smell that too. If the odor is heavily laced with gas then the "feel" will be more like WD40 rather than motor oil. Then that means gas is getting into the oil. I have always been pretty good with finding a problem using my nose, ear and fingers. I don't have a clue how to fix it, but know where the problem is. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 11, 2005 Author Share Posted September 11, 2005 TheSubaruJunkie said: White smoke is coolant. You need to make sure, when your swapping carbs, that you are using a new carburator gasket every time. If you do not, coolant will get from the water passage into the intake and that would cause the problem you are having right now. -Brian Thats possible... I had two new ones when I started, but I ended up re-using them... I have another one on the way, ill put the new one on when it gets here. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 11, 2005 Author Share Posted September 11, 2005 Seahag1978 said: K-man, How does the exhaust smell? Get right down on it... if it smells like a toasted marshmallow... coolant is just leaking by, if it smells like strong, normal exhaust then my guess is engine. Can you get a little oil out? Smell that too. If the odor is heavily laced with gas then the "feel" will be more like WD40 rather than motor oil. Then that means gas is getting into the oil. I have always been pretty good with finding a problem using my nose, ear and fingers. I don't have a clue how to fix it, but know where the problem is. Hmm, Ill have to try that, easy enough... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 11, 2005 Share Posted September 11, 2005 I bought a sheet of gasket paper from Kragen for like $3. Then I used the spacer on my EA81 as a stencil and cut out new ones everytime I did my carbs. Also, a good light coat of some sealant never hurts. -Brian Link to comment Share on other sites More sharing options...
Kostamojen Posted September 11, 2005 Author Share Posted September 11, 2005 It definatly doesnt smell like "roasted marshmellows", at least not to my nose... Definatly a strong smoke/exhaust smell. I checked the oil too and cant see any evidence of coolant mixing in. So, I painted one side of the car while I wait for my gaskets and other stuff (wont be here til the 15th or 16th): Link to comment Share on other sites More sharing options...
75subie Posted September 11, 2005 Share Posted September 11, 2005 looking good i am looking for one like yours:brow: Link to comment Share on other sites More sharing options...
Kostamojen Posted September 13, 2005 Author Share Posted September 13, 2005 And now I painted the whole car, woot! Link to comment Share on other sites More sharing options...
Kostamojen Posted September 14, 2005 Author Share Posted September 14, 2005 PCV valve replaced, no change (exept for no more leak). Still awaiting a new gasket... Link to comment Share on other sites More sharing options...
Seahag1978 Posted September 14, 2005 Share Posted September 14, 2005 Kostamojen said: It definatly doesnt smell like "roasted marshmellows", at least not to my nose... Definatly a strong smoke/exhaust smell. I checked the oil too and cant see any evidence of coolant mixing in. So, I painted one side of the car while I wait for my gaskets and other stuff (wont be here til the 15th or 16th): Oh, I see you were looking for coolant in the oil... look for gas in it... smell it and feel it. Did you do the compression test? Link to comment Share on other sites More sharing options...
Kostamojen Posted September 14, 2005 Author Share Posted September 14, 2005 Seahag1978 said: Did you do the compression test? Im taking it to a local shop that specializes in subarus. They will check that there, along with a few other things... I'm going to get the gasket on first of course. There doesnt seem to be any fuel in the oil either, the texture is right and theres no gas smell. Link to comment Share on other sites More sharing options...
