bella Posted September 8, 2005 Share Posted September 8, 2005 This morning I left to work with my car. After less than a mile my engine has stooped. The truth is that my gasoline indicator is showing me that is empty but my problem is that when I tried to start the car is starting and is dieing immediately. Now I am to work and tonight I will put some gasoline but the question is:If I have no fuel why for all that my engine starts even for 2-5 seconds? I really need an advice because tomorrow I want to go in vacation. THANK YOU. P.S. If I take off cap from the air filter and with engine stopped I accelerate, I'll be able to see in my carb if gasoline is coming.............? Link to comment Share on other sites More sharing options...
nkx Posted September 8, 2005 Share Posted September 8, 2005 the engine might be able to suck in enough gas fumes to run for a few seconds. i think if your tank was that empty, the car wouldnt be able to draw fuel in liquid form, and would only be running off of the fumes coming from the small puddle of gasoline at the bottom of the tank. Link to comment Share on other sites More sharing options...
subardoom Posted September 8, 2005 Share Posted September 8, 2005 This sound slike classic 'outta gas.' Put gas in and try it again. Is it carbed or injected? Either way, still sounds like it needs some petroleum distillate. Link to comment Share on other sites More sharing options...
bella Posted September 8, 2005 Author Share Posted September 8, 2005 Can I see with a digital multimeter if my induction coil is ok???What should I see on multimeter?? Link to comment Share on other sites More sharing options...
bella Posted September 8, 2005 Author Share Posted September 8, 2005 Thank You and if anyonne has others sugestions...... Link to comment Share on other sites More sharing options...
