Rear Brakes on 98 Forester
I just replaced the rear brake pads on a 98 Forester S.When driving down the road,I get a metal screeching noise..unless I apply gentle pressure to the brakes and it goes away.Are there shims I may have forgotten to install?
Yes. Did you use a genuine Subaru pad Kit? Those shims come with the kit.
While there can be a little noise for the first few stops while the pads 'wear in' ,if you've never done a brake job before, I can see where it would be easy to throw the shims/plates away accidently. Everything's the same color and those shims are stuck on sometimes with the anti'rattle grease/stuff so it isn't obvious it's a seperate component. I dunno about a metallic screeching - more like squealing. Still, quite likely.
Carl
