rruoho98 Posted September 10, 2005 Share Posted September 10, 2005 I have a 1991 Legacy, no dash lights, checked fuses, all of them I think and are all good. Bulbs are good too. My niece who I recently bought the car from thinks once she had a after market cd player put in, they no longer worked. Checked with a car radio business, they said no wires in that harness should be connected by loosing dash lights. Is there relays or other fuses labels "something else" I should be looking for. please help!! Link to comment Share on other sites More sharing options...
Cougar Posted September 12, 2005 Share Posted September 12, 2005 The display of the CD player may have a connection to go to the dash lights so it can be dimmed. I would check the dimmer control and see if there is voltage getting to and out of the control by using a test light probe. Link to comment Share on other sites More sharing options...
rruoho98 Posted September 12, 2005 Author Share Posted September 12, 2005 Thanks, I'll look into that. It's funny, tonight I was leaving walmart at dusk and I had no head lights. Got almost home and out of the blue, they started working!! The display of the CD player may have a connection to go to the dash lights so it can be dimmed. I would check the dimmer control and see if there is voltage getting to and out of the control by using a test light probe. Link to comment Share on other sites More sharing options...
rcoaster Posted September 12, 2005 Share Posted September 12, 2005 The display of the CD player may have a connection to go to the dash lights so it can be dimmed. I would check the dimmer control and see if there is voltage getting to and out of the control by using a test light probe. I once put in a aftermarket CD player in my 96 Outback, and somehow shorted out the dimmer wire. The result was no dash lights. Turned out to be a blown fuse, and simply replacing the fuse helped. Also, check to see if the dimmer switch is faulty. RC Link to comment Share on other sites More sharing options...
Legacy777 Posted September 12, 2005 Share Posted September 12, 2005 yup, check the fuse Link to comment Share on other sites More sharing options...
