Rear shock measurements, G3 Leone
WJM
I have a rear shock from my RX here, still fully assembled- it measures just a tiny bit over 18 3/4 inches from the top of the top nut to the center of the bottom bolt hole.
I measured from the top of the nut instead of the very tip of the shaft, because that little tab at the end that aids in disassembly of the shock is snapped off- hence the part still being assembled. :banghead:
