xoomer Posted September 14, 2005 Share Posted September 14, 2005 Well, found out what my timing problem was.... You know spin the dr side belt around... and then throw the passenger side on, Well I thought well if one was down and the other up it would work ok... then I couldn't figure my timing problem out... well I followed the instructions.. it works great now other than I maybe forgot to tighten a bolt and the t-belt came loose.. WARNING NOOB WITH A WRENCH! -x Link to comment Share on other sites More sharing options...
Humble Nuto 53 Posted September 14, 2005 Share Posted September 14, 2005 LOL, i know the feeling... never hurts to double check, triple, DOH Link to comment Share on other sites More sharing options...
Bobby_boucher Posted September 14, 2005 Share Posted September 14, 2005 That exactly how i felt when i broke my oil pump trying to get it off for the first time. Link to comment Share on other sites More sharing options...
jeffast Posted September 14, 2005 Share Posted September 14, 2005 i dropped my spare er27 ruining the only part i currentley need off it the oil pressure sensor so i know how you feel Link to comment Share on other sites More sharing options...
zyewdall Posted September 14, 2005 Share Posted September 14, 2005 i dropped my spare er27 ruining the only part i currentley need off it the oil pressure sensor so i know how you feel Just forget to tighten/threadlock the bolt holding the main crankshaft pully on... It'll come loose and you'll lose cooling and alternator in about 10 miles after starting your newly rebuilt engine. And when it comes loose it'll ream the center of the pulley out so you have to get a new one. I've tried it...... Link to comment Share on other sites More sharing options...
operose Posted September 15, 2005 Share Posted September 15, 2005 Just forget to tighten/threadlock the bolt holding the main crankshaft pully on... It'll come loose and you'll lose cooling and alternator in about 10 miles after starting your newly rebuilt engine. And when it comes loose it'll ream the center of the pulley out so you have to get a new one. I've tried it...... the previous owner of my legacy did that... I couldn't get another pully in time though so just lock-tite'd it and CRANKED THAT SUCKER DOWN... didn't have a torque wrench but based on my calculations with socket wrench and pipe and my weight we had about 150-160 ft-lbs of torque on that sucker... hasn't come loose yet but the car only made it 1000 miles before encountering another debilitating problem that I haven't had much time to research Link to comment Share on other sites More sharing options...
xoomer Posted September 15, 2005 Author Share Posted September 15, 2005 weelll now aparently I have stripped one of the tensinor dealys.. as in the thread was actually in the bolt.. so It won't go down tight...but I torqed the otherone and it seams to be stayin.. Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 16, 2005 Share Posted September 16, 2005 time for a helicoil buddy, take your time doing it and you'll love yourself for using it:D Link to comment Share on other sites More sharing options...
breaffyaviation Posted September 16, 2005 Share Posted September 16, 2005 time for a helicoil buddy, take your time doing it and you'll love yourself for using it:D Shouldent need a helicoil.I just tapped mine a size bigger.Worked fine ,took the torque. Jude Link to comment Share on other sites More sharing options...
