soobyfan Posted September 15, 2005 Share Posted September 15, 2005 My 96 OBW has the ABS light on, it just started today in the middle of a long day on the road. When I got home it was making noise in the area of the hydraulic unit under the hood, like a motor running or solenoids clicking continuously. The noise continued when I turned the ignition key off, and then stopped by itself about 10 minutes later. If I pull one or both of the relays out, will I still have normal braking? (with no abs of course) Any ideas on how to troubleshoot the system? Link to comment Share on other sites More sharing options...
ericem Posted September 15, 2005 Share Posted September 15, 2005 Same thing happened on my legacy i just disconnected the connector and the light went out, but it u take them out try some alchol or electronic cleaner then plug i back in worked for me, but u should have normal braking when the relay is out, just might slip. Link to comment Share on other sites More sharing options...
