mikkl Posted September 15, 2005 Share Posted September 15, 2005 Howdy folks. I have a new 2005 Legacy Sedan and need to install a front license plate (thank you Ohio...) The dealer has recommended two sheet metal screws directly into the bumper but I do not like the way that leaves the plate to be damaged and bent by anyone that walks by. Does anyone know of a front license plate bracket that would support the entire plate and fit the curvature of the front bumper? TIA, mikkl Link to comment Share on other sites More sharing options...
Commuter Posted September 15, 2005 Share Posted September 15, 2005 I find it hard to believe that Subaru does not have a front bracket or mounting scheme of some sort. I'm not sure if it is mandatory (I think it is), but we have front plates in Ontario as well. Commuter Link to comment Share on other sites More sharing options...
WAWalker Posted September 15, 2005 Share Posted September 15, 2005 Commuter said: I find it hard to believe that Subaru does not have a front bracket or mounting scheme of some sort. Commuter They do, to self tapping screws into the bumper cover. This is the factory recomended method. Link to comment Share on other sites More sharing options...
mwatt Posted September 15, 2005 Share Posted September 15, 2005 mikkl said: Howdy folks. I have a new 2005 Legacy Sedan and need to install a front license plate (thank you Ohio...) The dealer has recommended two sheet metal screws directly into the bumper but I do not like the way that leaves the plate to be damaged and bent by anyone that walks by. Does anyone know of a front license plate bracket that would support the entire plate and fit the curvature of the front bumper? TIA, mikkl Other than buying one of those aftermarket license plate frames to slightly "stiffen" the tag, it is the way it is. I can see your point about "fitting the curvature of the bumper". If it's any consolation, Subaru (as well as other manufacturers) have done front license plate mounting that way for years, now. Typically, there are two tiny "dimples" cast into the front bumper cover where you're supposed to force the self-tapping bolts in with a drill-driver. Link to comment Share on other sites More sharing options...
cweiss79 Posted September 16, 2005 Share Posted September 16, 2005 I have a 2000 Legacy GT that I bought a mounting bracket from a Subaru dealer. It sucks to have to screw in the mounting plate, but it's a decent looking setup. It's better than just screwing the plate on directly. mikkl said: Howdy folks. I have a new 2005 Legacy Sedan and need to install a front license plate (thank you Ohio...) The dealer has recommended two sheet metal screws directly into the bumper but I do not like the way that leaves the plate to be damaged and bent by anyone that walks by. Does anyone know of a front license plate bracket that would support the entire plate and fit the curvature of the front bumper? TIA, mikkl Link to comment Share on other sites More sharing options...
nipper Posted September 16, 2005 Share Posted September 16, 2005 I'll take a look at my freinds 2005 OBW tomorrow and see how they did it. nipper Link to comment Share on other sites More sharing options...
mikkl Posted September 16, 2005 Author Share Posted September 16, 2005 Commuter said: I find it hard to believe that Subaru does not have a front bracket or mounting scheme of some sort. Commuter I agree with you. The head of the spare parts department did suggest that I go looking on the internet as "some customers have found bracket there. Subaru, however, does not make them." Here in southern Ohio, you see a large number of new cars without front plates, even though they are required. A large number of Indiana and Kentucky (two states that do not require front plates) folks commute here for work and the Ohio folks seem to figure that the police will not be able to tell the difference as you drive by. It does maintain the good looks... mikkl Link to comment Share on other sites More sharing options...
powderhound Posted September 16, 2005 Share Posted September 16, 2005 We too are required to have front plates in WI. After mine got ripped off in an accident I never replaced it...until one day my kind county sherriff took time out from his busy schedule to interrupt my buzz cruise with a warning to get that thing on there. Mine is mounted with some wire around one of the lower pillars on the bumper cover. After pulling into a couple steep driveways it is now bent in half for maximum aerodynamic efficiency. Link to comment Share on other sites More sharing options...
nipper Posted September 18, 2005 Share Posted September 18, 2005 I looked at my freinds 2005 OBW today. The plate is mounted on the front bumper with self tapping screws. It looks more and more like GM mentality is sneaking into the subaru structure Joe Link to comment Share on other sites More sharing options...
mikkl Posted September 18, 2005 Author Share Posted September 18, 2005 Hey, thanks for checking. I was at Autozone yesterday picking up glaze and they have a "universal" plastic support bracket that I may try. Once the title shows up and I have plates in hand, I will start trying to figure out what looks best while still being legal. Thanks again, mikkl Link to comment Share on other sites More sharing options...
mikkl Posted October 12, 2005 Author Share Posted October 12, 2005 Well, I found a bracket. It is the bracket for the current generation of Chevy Cavalier, Pontiac Sunfire, and Saturn Ion. (Part number 22714457) $13 on ebay. It attaches with three pop-rivets (which means that I did have to drill holes in the bumper.) It provides secure attachment and a neat edge to the plate while protecting the paint. It is hard to take a picture of a black plastic frame on a black car with a bright white plate, but here goes: Thanks again for the comments and recommendations, mikkl Link to comment Share on other sites More sharing options...
xoomer Posted October 12, 2005 Share Posted October 12, 2005 See GM Mentality isn't all that bad?!?!? Did I just say that??? I paid 22K for an 03 Cavalier that had constant Brake Problems... and A Clutch that burned out at 21k and they (Dealership) wanted $3200 to fix!! And they hadn't released the clutch to any parts store. yet, As it wasn't even a year old at this point... I told the dealership to keep it! I later found out that it was sold at auction for 11k and rolled two weeks later... into a pond for that matter... Cheers.. to gm.. for crappy cars... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted October 12, 2005 Share Posted October 12, 2005 I am gonna get one of those plate backing units from Autozone for my OBW. It looks like it will allow some vertical position options as well as stiffening the support of the plate. I am loathe to put a plate on my WRX however and may wait until the 'squeezers' suggest I do so. And when that happenes I may try to make a plate holder that uses the front tow hook recepticle. Link to comment Share on other sites More sharing options...
mikkl Posted October 13, 2005 Author Share Posted October 13, 2005 1 Lucky Texan said: I am gonna get one of those plate backing units from Autozone for my OBW. It looks like it will allow some vertical position options as well as stiffening the support of the plate. I can't blame you for looking at those. I will probably be using one on my wife's Toyota. Since I had to drill holes in my bumper, I had a fairly large range of options regarding the location. mikkl Link to comment Share on other sites More sharing options...
