Trail fix for CV boots
soobme
I got 2 of 'em for y'all. The 1st I used last weekend with good results. Shrink wrap! This can be put on even if the CV is still on the car:D I had a roll of 3" wide and made 4 or 5 full wraps of the CV with it and it held for the whole day of wheelin'. I bet that seran wrap would work too if U used enough.
2nd: motorcycle inertoob, cut a 8"-9" section of it and hose clamp or zip-tye it on. U would have to take the axle out of the car to do this, but I bet it would hold up for a while if done right;) Just thought I would share:drunk:
Good ideas.
I would think that rubber electrician's tape would work, too. Not the plastic kind, but the natural rubber type that's used to waterproof a connection. Usually comes with a paper backing that you peel off as you unwind what you need. With enough turns, the rubber layers will actually blend together into a single contiguous material with all the attributes of rubber (pliable, stretchable, etc.). Might be a good thing to have in your tool box. Then again, maybe it wouldn't work... 8-) Later, Rick
