syphon Posted September 23, 2003 Share Posted September 23, 2003 So last night I rotated my tires. Right Rear switched with Left Front and then LR switched RF. Anyone who saw my tires at Evans Creek will know my front tires were bald as hell. Now... the car has a pretty serious shake. It used to shake on the freeway before, but now it's gotten slightly worse. Instead of a death-rattle at 75, it shakes at any speed above 50 (and most speeds below 50). I've checked the air pressure in the tires, is there anything else anyone can think of? PS. Another issue, most likely unrelated... The tread on my front tires had very uneven wear. The outside of the tread was bald as can be, but the tread on the very inside was still good. Any ideas? Link to comment Share on other sites More sharing options...
JonOfScio Posted September 23, 2003 Share Posted September 23, 2003 I think your camber needs to be adjusted. Link to comment Share on other sites More sharing options...
struculeus Posted September 23, 2003 Share Posted September 23, 2003 The car shakes because your wheels are out of balance. Get the tires balanced, your shake and shimmy shall cease. I love saying shake and shimmy. I just don't get to use it enough. J Link to comment Share on other sites More sharing options...
GLCraig Posted September 23, 2003 Share Posted September 23, 2003 Well your shake problem is most likely an unbalance tire or maybe a bent wheel. You might try loosening the lug nuts and then tightening them to 70ft-lbs sometimes, uneven torque on the lug nuts will cause some wheel shake. As for your rotation, you should rotate LF to LR and RF to RR with radial tires. If you have directional tires, it's a must. The tire wear that you mention is pretty common with EA81s, hard cornering will increase the rate of outside wear. Link to comment Share on other sites More sharing options...
felipe01forester Posted January 1, 2005 Share Posted January 1, 2005 If there is one in your area, go to the good people at Discount Tires. All minor stuff (balancing, patching, stem repair) is totally free. Link to comment Share on other sites More sharing options...
Skip Posted January 1, 2005 Share Posted January 1, 2005 my check mark goes beside a broken belt in one of the front tires if you are serious about fixing this jack each wheel off the ground spin it and watch for irregularities I am also behind Craig in his Lf - > Lr I believe your method went out with bias ply tyres but I'm brain dead so please pay no attention Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 1, 2005 Share Posted January 1, 2005 Its usually and supposed to be free, but it helps to bring a good looking girl, its always free then, but its hit or miss if you show up alone. I'm assuming this is on the Turbo? because i don't know what other cars you have. the wear is obviously from where the tires were and not where they are now. the imbalance will be magnified on the front as compared with the back. if this is the legacy, it could be the new wrx struts you put in, they could be affecting your camber and caster, and toe even. Link to comment Share on other sites More sharing options...
Subarutex Posted January 1, 2005 Share Posted January 1, 2005 People really need to stop bumping threads from years ago!! Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 1, 2005 Share Posted January 1, 2005 HAHAHA, but maybe he's still having the same problem. I sure hope he's not, cause if he hasnt gotten the problem fixed by now, that probably means he blew one of his tires out or something. I don't think Jay could drive this long with that shaking. -Brian Link to comment Share on other sites More sharing options...
jazzician Posted January 2, 2005 Share Posted January 2, 2005 Is there snow where you are? I found that I got some snow stuck in the wheels somewhere and threw off the weight balance. simon Link to comment Share on other sites More sharing options...
heartless Posted January 2, 2005 Share Posted January 2, 2005 Had a similar problem last year - thought I had a ball joint or something going - took the car in to get it checked out and they found out one wheel was bent - slightly - but enough that it couldnt be balanced properly. Thank goodness for parts cars, traded out that wheel and problem solved! Link to comment Share on other sites More sharing options...
syphon Posted January 2, 2005 Author Share Posted January 2, 2005 Holy Cow people! This thread is ancient! Check the dates of the first few posts... Rotated tires... car shook like mad. Bought new tires, car still shook, but was acceptable (hey, it was an old car). Sold car, bought newer car, have been driving that car for about a year now. In fact, the car this thread was written over has been wrecked for almost a year now (by the people I sold it to). Link to comment Share on other sites More sharing options...
Snowman Posted January 2, 2005 Share Posted January 2, 2005 Wow, this an old thread. Link to comment Share on other sites More sharing options...
syphon Posted January 2, 2005 Author Share Posted January 2, 2005 I think that I was confused as to why the car would shake AFTER rotating the tires when it wasnt so bad before. It didn't make sense that the tires were out of balance since they rode semi-ok before the rotation. In Retrospect, they MIGHT have been directional tires (but I doubt it) and I swapped them on backwards. Oh well, like I said, the car has long since been fixed, sold, then wrecked Link to comment Share on other sites More sharing options...
