paulbellefeuille Posted September 18, 2005 Share Posted September 18, 2005 Howdy, Is the air cleaner housing..the box on the right fender..the same for the '93 Legacy Turbo as it is for the Non-turbo? Thanks for the help! Quote Link to comment Share on other sites More sharing options...
unverviking Posted September 18, 2005 Share Posted September 18, 2005 On my 93 Wagon, it was on the left hand side (Passenger side) It was secured by a combination hex/phillips screw/bolt. I had to use hex, the phillips was stripped out... Not sure on the turbo ?? Hope that this helps... Quote Link to comment Share on other sites More sharing options...
Olnick Posted September 18, 2005 Share Posted September 18, 2005 A note: For the sake of clarity in communications, directions in a vehicle are generally given from the operator's driiving position--thus the passenger side is the right side of the car. Sorry, not intended to be smarta$$, just to clarify. Quote Link to comment Share on other sites More sharing options...
paulbellefeuille Posted September 18, 2005 Author Share Posted September 18, 2005 Duly noted. I meant the right side.. I must have been asleep when I posted the question..or it's a sign of advancing age..lol! A note: For the sake of clarity in communications, directions in a vehicle are generally given from the operator's driiving position--thus the passenger side is the right side of the car. Sorry, not intended to be smarta$$, just to clarify. Quote Link to comment Share on other sites More sharing options...
Olnick Posted September 18, 2005 Share Posted September 18, 2005 No, no, no, paulbellefeuille--you had it right (correct) to begin with!!! Right (okay)? Gads, this language of ours can be confusing though! Quote Link to comment Share on other sites More sharing options...
jamal Posted September 18, 2005 Share Posted September 18, 2005 In any case, I believe the turbo and non-turbo housings are different. Quote Link to comment Share on other sites More sharing options...
unverviking Posted September 19, 2005 Share Posted September 19, 2005 A note: For the sake of clarity in communications, directions in a vehicle are generally given from the operator's driiving position--thus the passenger side is the right side of the car. Sorry, not intended to be smarta$$, just to clarify. oops, my bad... I calls it like I sees it... I was visualizing the air cleaner in my head and had it on the left... Not thinking that the right is generally the passenger side... Oh well... Thanks for clarifying... Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted September 19, 2005 Share Posted September 19, 2005 In any case, I believe the turbo and non-turbo housings are different. The turbo and non-turbo air cleaner boxes are the same. Quote Link to comment Share on other sites More sharing options...
paulbellefeuille Posted September 19, 2005 Author Share Posted September 19, 2005 Thanks for the info! The turbo and non-turbo air cleaner boxes are the same. Quote Link to comment Share on other sites More sharing options...
