Guest synapse79 Posted September 24, 2003 Share Posted September 24, 2003 The last two or three trips to the local part shop, i received the wrong sized crush washer.. I dont want to have to reuse the old one again.. Can somebody tell me the ID of the crush washer for a 98 2.2? I dont want to leave the shop til i got the right one thanks jason what gives with our SNs not carrying over from the old board.. Link to comment Share on other sites More sharing options...
GLCraig Posted September 24, 2003 Share Posted September 24, 2003 I'm not sure about the size but the dealers sell them for less then a $1.00 and they will last for 3 or more oil changes. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted September 24, 2003 Share Posted September 24, 2003 You reuse them??? They are SOOO cheap I figure its worth changing them out each time. As far as I understand all subarus use the same washer... my 87 GL and my moms 96 OBS use the same washer (but different filters) I belive I pay around 70 cents for my washers. Link to comment Share on other sites More sharing options...
Setright Posted September 24, 2003 Share Posted September 24, 2003 Crush washers should not be used twice. Link to comment Share on other sites More sharing options...
Guest synapse79 Posted September 24, 2003 Share Posted September 24, 2003 i think mine is on its third use... its a little hard to go get one, when there is no oil in the oil pan.. doesnt anybody know the diameter of the drainplug? Link to comment Share on other sites More sharing options...
North Ursalia Posted September 25, 2003 Share Posted September 25, 2003 On an OEM crush washer, the ID is 20mm and the OD is 26mm. The drain bolt itself is 19mm x 1.25 pitch IIRC. Link to comment Share on other sites More sharing options...
Guest synapse79 Posted September 29, 2003 Share Posted September 29, 2003 thanks for the info thats what i wanted to know Link to comment Share on other sites More sharing options...
Guest synapse79 Posted September 29, 2003 Share Posted September 29, 2003 crazy FHI.. always using that 1.25 pitch.. Link to comment Share on other sites More sharing options...
pianodirt Posted September 29, 2003 Share Posted September 29, 2003 speaking of washers, anyone know offhand what size is needed to replace the manual transaxle/differential drainplug washer on an ea82? Link to comment Share on other sites More sharing options...
applegump Posted September 29, 2003 Share Posted September 29, 2003 good to know! Link to comment Share on other sites More sharing options...
North Ursalia Posted September 29, 2003 Share Posted September 29, 2003 ID is 27mm and OD is 30mm. For the $.75 or $1.00 these things cost, I don't know why people are going through soooooooo much trouble to find something aftermarket though... I should do a 'group buy' on drain gaskets ! Link to comment Share on other sites More sharing options...
jcniest5 Posted September 30, 2003 Share Posted September 30, 2003 Hehehehe...talking about replacing washer at each oil change, I've never even thought of replacing it. It didn't even cross my mind about replacing it. I've always thought I should reuse the old one until it breaks. How's that for a change? LOL Link to comment Share on other sites More sharing options...
Tiny Clark Posted September 30, 2003 Share Posted September 30, 2003 I never changed mine out either, until the recent Fumoto valve upgrade. Never had a drop of a leak. Link to comment Share on other sites More sharing options...
