Ozmodiar-X Posted September 21, 2005 Share Posted September 21, 2005 Can some youguys help me fill this out? Its for an 1987 GL hatch, 1.8L, 2WD. Non-turbo. Link to comment Share on other sites More sharing options...
JWX Posted September 21, 2005 Share Posted September 21, 2005 OHC or OHV Link to comment Share on other sites More sharing options...
TROGDOR! Posted September 21, 2005 Share Posted September 21, 2005 OHC/OHV, 4 headlights or 2, FI or Carb, any one of those will tell us what we need to know. Subaru made 2 body styles with a hatchback in 1987. Link to comment Share on other sites More sharing options...
Ozmodiar-X Posted September 22, 2005 Author Share Posted September 22, 2005 um not sure about the OHV or OHC, all i know its a 4 cylinder 1.8 L boxer, 2 headlights, FI, Link to comment Share on other sites More sharing options...
calebz Posted September 22, 2005 Share Posted September 22, 2005 Ozmodiar-X said: , FI, ea82 90 something HP 1781cc 9.5:1 CR 13 inch wheels Link to comment Share on other sites More sharing options...
Ozmodiar-X Posted September 22, 2005 Author Share Posted September 22, 2005 no more help? Link to comment Share on other sites More sharing options...
TROGDOR! Posted September 22, 2005 Share Posted September 22, 2005 Much of this info can be found in the back of the owners' manual. Unfortunately I don't have one handy. Link to comment Share on other sites More sharing options...
Ozmodiar-X Posted September 22, 2005 Author Share Posted September 22, 2005 also, i don't have one:banghead: Link to comment Share on other sites More sharing options...
zyewdall Posted September 22, 2005 Share Posted September 22, 2005 Ozmodiar-X said: also, i don't have one:banghead: The chilton's manual actually has tables of much of this info. Link to comment Share on other sites More sharing options...
TROGDOR! Posted September 22, 2005 Share Posted September 22, 2005 Ozmodiar-X said: Can some youguys help me fill this out? Its for an 1987 GL hatch, 1.8L, 2WD. Non-turbo. Engine specs from this page: http://www.ultimatesubaru.org/80s/specs/mechanical/engine-specs.html 1781cc, 90hp@5600rpm, 101tq@2800rpm (listed under 86-94 SPFI) Location would obviously be front, layout flat 4 From the 1988 owners manual, should be the same as 87: Compression ratio 9.5:1 Redline 6500rpm Gear ratios: 1: 3.636 2: 1.950 3: 1.344 4: 0.971 5: 0.783 R: 3.583 Final: 3.900:1 Front wheel drive 5 speed manual of course. Weight: take it to a truck stop. Weight distribution: your guess is as good as mine. Heavier in the front than the rear, but no idea as to ratio. Wheelbase: 97.2in Tire section width: Check the first number on the tire size. Stock is 175mm. Wheel diameter: 13" Tire profile: Check the second number on the tire size. Stock is 70% of 175mm, or a "70" profile. Coefficient of drag: lots. Something like .45 I believe, don't quote me on that. Height: 51.8in Width: 65.4in Ground clearance: 5.1in You owe me a beer for this. Link to comment Share on other sites More sharing options...
Ozmodiar-X Posted September 26, 2005 Author Share Posted September 26, 2005 Thanks so much! Link to comment Share on other sites More sharing options...
