LosDiosDeVerde86 Posted September 23, 2005 Author Share Posted September 23, 2005 I would post to say that you can get some nice skidplates for the EJ cars, and they are only like $150 or so. Perhaps Rallitek carries them. http://www.rallitek.com/products.asp?ID=741&PP=Y&HB=&ACC=&SP= However, since you haven't asked and seem to have an overly sarcastic tone about you, i'll just let you be. Have fun. well fine then...i'll just ignore your message, not click on the link, and therefore not thank you for the trouble of helping me out.. thanks Link to comment Share on other sites More sharing options...
Subarutex Posted September 23, 2005 Share Posted September 23, 2005 I believe Primitive Racing also makes a skid plate for EJ cars. It would be a bit meaner than that Rallitek one, as its intended for rally. Link to comment Share on other sites More sharing options...
operose Posted September 23, 2005 Share Posted September 23, 2005 I'm gonna build a gnarly skid plate for my xt6... partially so it will slide over the snow better this winter when I'm in the deep stuff Link to comment Share on other sites More sharing options...
Kostamojen Posted September 24, 2005 Share Posted September 24, 2005 I believe Primitive Racing also makes a skid plate for EJ cars. It would be a bit meaner than that Rallitek one, as its intended for rally. I didnt know nobody in this thread knew about Primitive or I would have posted the link with my post... So here it is: http://www.writerguy.com/primitive/skid.htm FYI, get the 3/16th Link to comment Share on other sites More sharing options...
johnnyk Posted September 24, 2005 Share Posted September 24, 2005 sounds good is the spedometer effected? are there any easy ways to correct it? Link to comment Share on other sites More sharing options...
Andyjo Posted September 24, 2005 Share Posted September 24, 2005 what... why would a skid plate alter your speedometer reading..... not at all Link to comment Share on other sites More sharing options...
ezapar Posted September 24, 2005 Share Posted September 24, 2005 what... why would a skid plate alter your speedometer reading..... not at all Actually, I think that a search for skidplate/speedometer/ratios will turn up the correct answers. Shouldn't be much more than 25% + or - if the skid plate's not too thick. Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted September 24, 2005 Author Share Posted September 24, 2005 sounds goodis the spedometer effected? are there any easy ways to correct it? it's off by about 12% Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted September 24, 2005 Author Share Posted September 24, 2005 it's off by about 12% ...because of the tires....not the skid plate. Link to comment Share on other sites More sharing options...
alexk02 Posted September 28, 2005 Share Posted September 28, 2005 96 Legacy ls + outback struts + 205/75R15 Wilderness AT's w/ 5/32nds tread = 9.5" clearance at the pinch and 10" at the rear diff... not too shabby pics to come no body lift by the way LosDios, still waiting for those pics. No problems with tires rubbing against innner fender or splash guards during tight turns/compressions or you did some modifications? So the lift is entirely due to taller tires, while all OB struts are doing is allowing to mount those tall tires? Otherwise everything is stock? Link to comment Share on other sites More sharing options...
Numbchux Posted September 28, 2005 Share Posted September 28, 2005 LosDios, still waiting for those pics. No problems with tires rubbing against innner fender or splash guards during tight turns/compressions or you did some modifications? So the lift is entirely due to taller tires, while all OB struts are doing is allowing to mount those tall tires? Otherwise everything is stock? not quite, the OB struts are longer too... Link to comment Share on other sites More sharing options...
alexk02 Posted September 28, 2005 Share Posted September 28, 2005 not quite, the OB struts are longer too... I thought that struts do not add to height of the vehicle, just facilitate shock absorbtion. The springs, on the other hand, are the ones that keep the shocks at about the middle of their travel, so that it is the springs that will support the car body higher up (in addition to any lift kit which basically adds shims to various points of suspension/drivetrain/body contacts. Link to comment Share on other sites More sharing options...
Numbchux Posted September 28, 2005 Share Posted September 28, 2005 I thought that struts do not add to height of the vehicle, just facilitate shock absorbtion. The springs, on the other hand, are the ones that keep the shocks at about the middle of their travel, so that it is the springs that will support the car body higher up (in addition to any lift kit which basically adds shims to various points of suspension/drivetrain/body contacts. true, but so can the struts, the struts are longer between the bottom spring mount, and where it attaches at the bottom. same idea, but different. you can also add tighter springs (like those off an OB, or forester) and lift it more. Link to comment Share on other sites More sharing options...
alexk02 Posted September 29, 2005 Share Posted September 29, 2005 true, but so can the struts, the struts are longer between the bottom spring mount, and where it attaches at the bottom. same idea, but different. you can also add tighter springs (like those off an OB, or forester) and lift it more. Now I got it. Thanks, Chux. Alex Link to comment Share on other sites More sharing options...
SubyNoobie Posted October 5, 2005 Share Posted October 5, 2005 I thought that struts do not add to height of the vehicle, just facilitate shock absorbtion. The springs, on the other hand, are the ones that keep the shocks at about the middle of their travel, so that it is the springs that will support the car body higher up (in addition to any lift kit which basically adds shims to various points of suspension/drivetrain/body contacts. Here's a pic of the difference between a 95 Legacy LS strut and a 96 Legacy Outback strut... http://www.ultimatesubaru.org/photos/showphoto.php?photo=7534&size=big&sort=1&cat=500&page=1 As you can see, the new strut is longer. (That's the Outback strut) So the plate that the springs rest on is higher, therefore raising the car. I've only completed raising the front due to laziness.. I'll raise the rear later. My car looks very funny with the front raised and the back not... Link to comment Share on other sites More sharing options...
Kostamojen Posted October 5, 2005 Share Posted October 5, 2005 Here's a pic of the difference between a 95 Legacy LS strut and a 96 Legacy Outback strut... http://www.ultimatesubaru.org/photos/showphoto.php?photo=7534&size=big&sort=1&cat=500&page=1 As you can see, the new strut is longer. (That's the Outback strut) So the plate that the springs rest on is higher, therefore raising the car. I've only completed raising the front due to laziness.. I'll raise the rear later. My car looks very funny with the front raised and the back not... How much were the outback GR2's? Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 5, 2005 Author Share Posted October 5, 2005 LosDios, still waiting for those pics. No problems with tires rubbing against innner fender or splash guards during tight turns/compressions or you did some modifications? So the lift is entirely due to taller tires, while all OB struts are doing is allowing to mount those tall tires? Otherwise everything is stock? rubs on hard turns yeah stock aside from Hellas and cherry bomb removed intake silencer, cherry bomb, OB struts, 205/75R15 firestone wildernesses, 2 hella 500's and i'm wrking on taking a 3rd brakelight housing from a ford tauras and making it a hood scoop Link to comment Share on other sites More sharing options...
scoobyclimbs Posted October 5, 2005 Share Posted October 5, 2005 Ground clearance on my outback is great .However ,the body clearance is what sux! That's where the Hummer and other 4x4's have the advantage!!! Link to comment Share on other sites More sharing options...
Zefy Posted October 5, 2005 Share Posted October 5, 2005 scoobyclimbs Ground clearance on my outback is great .However ,the body clearance is what sux! That's where the Hummer and other 4x4's have the advantage!!! ya the outbacks have a fat arse... when i drive my parents legacy it always feels like i'm gonna hit something with it... Link to comment Share on other sites More sharing options...
Kostamojen Posted October 6, 2005 Share Posted October 6, 2005 Ground clearance on my outback is great .However ,the body clearance is what sux! That's where the Hummer and other 4x4's have the advantage!!! Ya, I actually think my Impreza would have better body clearance in that reguard... Without the bumpers (not the metal part, the covers) , and with a body lift, it could have very steep entry/departure angles. Link to comment Share on other sites More sharing options...
SubyNoobie Posted October 7, 2005 Share Posted October 7, 2005 How much were the outback GR2's? I want to say around $65 each at rockauto.com plus shipping. Be sure to order the Bellows too, if your current ones are blown, which is very likely. Bellows are $15 each, plus shipping.. Be sure to have spring strut compressors. I had posted some time earlier a writeup on doing this... I'm sure you could find it by looking up all of my posts, or doing a search. If not, I might be able to find it. My recommendation is to go to the KYB website, find the model #'s you need from their site for a 96 Outback, since I think I remember your tagline stating having a 95 Legacy? Anyhow, it gained me around 1.5" gain.. If I were to add stiffer or Outback Springs, it would likely gain me the full 2" that everyone on here seems to pimp. Of course, now my camber is screwed up, so I'll have to get that fixed by someone with a bit more automotive skill than I. (Like a real mechanic.) I'll have to upload my before/after pix some time soon when I'm not feeling lazy.. Link to comment Share on other sites More sharing options...
Kostamojen Posted October 7, 2005 Share Posted October 7, 2005 How fubared is the camber? If its over fubared, might need camber plates... Link to comment Share on other sites More sharing options...
