Aftermarket ignition module installation.
i think the disty in the rx is optically triggered, eithe that or a hall effect switch. if you look under the plate that goes under the rotor, there is a thin metal disk with tiny little holes along the edge of it, that passes through a pick up, looks like its an optical pick up.
