High Pitched noises - Timing Belt?
Yesterday I replaced the timing belt on EJ22 Engine, didn't have any problems at all (lucky I had previous experience on EA82 engine), had a bit of hiccups but all went smoothly, it was 3pm Saturday noon when I was putting together, I realised the rubber seals was falling apart due leaky power steering pump seal (just replaced yesterday as well) as it was too hard to keep them together/one piece, so I put the cover back on without the seals that goes between timing belt cover to rear belt cover/engine block. Now I started up the engine and it has an high pitched squealing noises (didn't have the vee belts for Air Con/Power Steering)... I knew I did double check on all belts ensuring they are all very tight - used torque wrench on the pulleys etc.
Two things that I could be suspected are either -
The timing belt is too tight? (I had 2nd person to help me to put the belt on but man it was so tight) Or Do I have to loosen the belt tension adjustor as its already on tight spot - I didn't touch that when I did the belt.
Or
Is it due because of the seals between the timing belt covers?
OR
Could be something else? ie bearings?
Tomorrow noon I will go to Subaru and buy some new seals for it.
Cheers & thanks.
AP
it must have been a real *************** to fit the belts with the tensioner in place you should back it off to fit the belts the noise could be the belts/pulleys rubbing on the covers the rubber seals missing could affect the clearance
regards camo
<<The timing belt is too tight? (I had 2nd person to help me to put the belt on but man it was so tight) Or Do I have to loosen the belt tension adjustor as its already on tight spot - I didn't touch that when I did the belt.>>
you didn't remove the tentioner and re-set it? if you didn't remove that, then who knows what else could have been skipped in the process.
No wonder the belt was tight. It would be a good idea to go back inside, compress the belt tensioner, and reinstall the timing belt the right way. I don't know how you got the belt back on without compressing the tensioner, but it seems to me you would have to pry on the pulley with a bar or something to get enough slack to get the belt on.
That might damage the bearings in the idler pulley, causing the squeal? Just a thought???
Matt D
  • 2 months later...
