iluvdrt Posted September 25, 2005 Share Posted September 25, 2005 I am getting no spark from my coil. I have changed the ignitor, distributor, coil, all fuses, all Ign componets are new, timing belts are good(I dont have a cover so I can see them), Everything. Still no spark. The only thing I didnt change was my ecm. I am getting 12 volts to the coil, dizzy, and ignitor. Why no spark? Thanks. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted September 25, 2005 Share Posted September 25, 2005 only thing I could suggest is to follow the troubleshooting guide from the EA82 Part 2 manual, on (or around) page 53 of the pdf http://www.finleyweb.net/default.asp?id=142 Link to comment Share on other sites More sharing options...
iluvdrt Posted September 25, 2005 Author Share Posted September 25, 2005 hooziewhatsit said: only thing I could suggest is to follow the troubleshooting guide from the EA82 Part 2 manual, on (or around) page 53 of the pdf http://www.finleyweb.net/default.asp?id=142 Thanks, I have my FSM's here, and they are basically telling me to look for an unplugged plug (they are all plugged in) or a short in the harness. It doesnt tell me what needs voltage where, and what resistance values for componets. Link to comment Share on other sites More sharing options...
iluvdrt Posted September 25, 2005 Author Share Posted September 25, 2005 OK, basically what I have found is, is this: 12 volts to new coil 12volts to new dizzy 12 volts to new ignitor Everything has power, is there anything else in this scenario that I am missing? There are 2 plugs coming off of the coil, 1 going to the ignitor, and the second one goes where? The Tach I am guessing, which would have no impact on not having spark right? Link to comment Share on other sites More sharing options...
zyewdall Posted September 25, 2005 Share Posted September 25, 2005 iluvdrt said: OK, basically what I have found is, is this: 12 volts to new coil 12volts to new dizzy 12 volts to new ignitor Everything has power, is there anything else in this scenario that I am missing? There are 2 plugs coming off of the coil, 1 going to the ignitor, and the second one goes where? The Tach I am guessing, which would have no impact on not having spark right? Is the ECU giving any codes to narrow down which part it doesn't like? Only suggestion I have is to replace new components with old ones one at a time (if it ran with the old ones). Every once in a while, you buy a new part thats DOA. Link to comment Share on other sites More sharing options...
iluvdrt Posted September 26, 2005 Author Share Posted September 26, 2005 I gave up, its for sale now. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted September 26, 2005 Share Posted September 26, 2005 have you checked the neg side of the coil to see if you're getting pulses from the distributer? It's easiest to check this while cranking the engine over by hand, not with the starter. If it doesn't, it points to either a bad disty, bad ECU, or a open in the wiring harness somewhere. page 53 of that pdf shows one pin from the coil transistor going to +12 through fuse 11, and the other pin goes to the ECU. Link to comment Share on other sites More sharing options...
iluvdrt Posted September 26, 2005 Author Share Posted September 26, 2005 hooziewhatsit said: have you checked the neg side of the coil to see if you're getting pulses from the distributer? It's easiest to check this while cranking the engine over by hand, not with the starter. If it doesn't, it points to either a bad disty, bad ECU, or a open in the wiring harness somewhere. page 53 of that pdf shows one pin from the coil transistor going to +12 through fuse 11, and the other pin goes to the ECU. Yuppers. I checked everything, me and my pops ( i had to call in re-enforcements) I dont know. I am sick of messing with it. This has been an ongoing battle for a few years now....every since the new engine. I am tired of messing with it. Link to comment Share on other sites More sharing options...
Sister7 Posted September 26, 2005 Share Posted September 26, 2005 There is some type of transistor on the bottom of the coil bracket that gives you no spark when it goes. Also the coil bracket is a ground, so make sure it's clean. Link to comment Share on other sites More sharing options...
Ross Posted September 26, 2005 Share Posted September 26, 2005 So, are there pulses getting to the coil or not? Link to comment Share on other sites More sharing options...
iluvdrt Posted September 26, 2005 Author Share Posted September 26, 2005 Ross said: So, are there pulses getting to the coil or not? Well the coil has voltage on each side like it should. The dizzy is getting voltage. I replaced the amplifier, and still nothing. The bracket is tight and clean against the firewall. Maybe I should make an extra ground wire and attach it to the bracket? I dont know. Link to comment Share on other sites More sharing options...
Cougar Posted September 27, 2005 Share Posted September 27, 2005 Two more things to check. Be sure fuse #5 is good. Also check the ECU for codes. Let us know what you find. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted September 27, 2005 Share Posted September 27, 2005 iluvdrt said: Well the coil has voltage on each side like it should. The dizzy is getting voltage.I replaced the amplifier, and still nothing. The bracket is tight and clean against the firewall. Maybe I should make an extra ground wire and attach it to the bracket? I dont know. just because they have power don't mean they're working correctly. Also, just because they're new/different doesn't mean they're good. Do you have pulses at the neg side of the coil? Link to comment Share on other sites More sharing options...
