New lift torque specs
mtnman38
  • 6 months later...
So yea I just went with the stock specs . It seems to be working well At least I have a base line so I dont get over zellus with the bolts each time
yeah just make sure you go back a week or so later and tighten everything back down, and threadlock/locktite is a good idea. Also I dont know exactly what bolts AA uses, but I used 1/2" grade 8 bolts, I'd LOOOVE to see someone strip one o those without pulling out the 5ft breakerbar extension...
Really tight is good, but too tight is bad because if some blocks arent tied together, things will move and flex and you will be snapping bolts, like I did... but then again I also have 6" of lift.
