mattinhg Posted September 26, 2005 Share Posted September 26, 2005 Hi, long time looker, first time user. I have an 87 Gl Wagon 4wd EA82 dual range with a few things that I cannot figure out. 1. Hill Holder leaking- I cannot seem to find the right o-ring size for rebuild. Am I doing something wrong? 2. Carbeurator adj- What are the factory settings? Where is the fuel/air mixture screw? I am running too rich. any advice would be appreciated, Thanks, Matt Link to comment Share on other sites More sharing options...
torxxx Posted September 26, 2005 Share Posted September 26, 2005 Hill holder - dont rebuild it, find a used unit. prolly be a lot easier. If I remember correctly, the hill holder unit is built into the master cylinder right? (At the library, or I'd go check on my wagon) When you get the "new"/used master cylinder on there, leave the hill holder unhooked. With a working hand brake you dont need a hill holder. The carb mixture screw is capped off on the front of the carb. It has a 1/2" or 5/8" cap over it with a slight indentation in the middle of the cap (Might even have a slight X across the top of it.) Make sure when you drill out the cap, you dont drill into the mixture screw, or spin the mixture screw with the drill bit. I used a 3/8" drill bit when I drilled mine out. Good luck Link to comment Share on other sites More sharing options...
mattinhg Posted September 27, 2005 Author Share Posted September 27, 2005 Thanks for the tech, these problems have been driving me crazy. The hill holder is a separate unit directly under the MC, with some sort of linkage to the clutch. Is this linkage necessary? They want $200 for a used one, that's what I paid for the whole car! I can live w/o it. Why in the hell did they cap off the fuel/air? I thought that I was a moron bc I could not find it. How about this one: RF wheel has slight wobble @ 35, 65, & 85 mph. Replaced outer tie rod ends, front end alignment, balanced the wheel. What is it? Bent wheel? CV? rack n pinion? wheel bearing? Thanks again, -M Hill holder - dont rebuild it, find a used unit. prolly be a lot easier. If I remember correctly, the hill holder unit is built into the master cylinder right? (At the library, or I'd go check on my wagon) When you get the "new"/used master cylinder on there, leave the hill holder unhooked. With a working hand brake you dont need a hill holder. The carb mixture screw is capped off on the front of the carb. It has a 1/2" or 5/8" cap over it with a slight indentation in the middle of the cap (Might even have a slight X across the top of it.) Make sure when you drill out the cap, you dont drill into the mixture screw, or spin the mixture screw with the drill bit. I used a 3/8" drill bit when I drilled mine out. Good luck Link to comment Share on other sites More sharing options...
