97OBW Posted September 26, 2005 Share Posted September 26, 2005 i have a 97 obw and when i go start it, it starts then it stutters and shuts off. what is the problem here!!!??? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted September 26, 2005 Share Posted September 26, 2005 Sounds like an issue in fuel delivery.Just a guess.Check your fuel filter. Link to comment Share on other sites More sharing options...
97OBW Posted September 26, 2005 Author Share Posted September 26, 2005 anything i can check without removeing some screws and bolts? Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 26, 2005 Share Posted September 26, 2005 check for vacuume leaks, happens to me every once in a while, some of the big hoses, when they fall off the plastic intake tube will stall the motor real quick. Link to comment Share on other sites More sharing options...
Dickensheets Posted September 26, 2005 Share Posted September 26, 2005 Did you fiddle with the air filter recently? If so, look under the air intake tube just past the MAF and make sure all the little hoses are still attatched. Ask me how I know. Ryan Link to comment Share on other sites More sharing options...
MorganM Posted September 26, 2005 Share Posted September 26, 2005 With the extremely limited amount of info. My guess is Mass Air Flow sensor. Link to comment Share on other sites More sharing options...
97OBW Posted September 26, 2005 Author Share Posted September 26, 2005 Did you fiddle with the air filter recently? If so, look under the air intake tube just past the MAF and make sure all the little hoses are still attatched. Ask me how I know. Ryan WOW !!I did fiddle with the air filter riiight before this morning, post some info pleasE!! i already have a tow truck comin in tommorow 100$!!! Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 26, 2005 Share Posted September 26, 2005 Ask me how I know. Probably the same way i know, oh man can that be frustrating if you gotta be somewhere soon and the car dosn't run. Link to comment Share on other sites More sharing options...
Suzam Posted September 26, 2005 Share Posted September 26, 2005 Check the underside of the air cleaner assembly about halfway to the wheelwell, you should see a tube about 1.5 - 2 inches in diameter that needs to be reattached. Link to comment Share on other sites More sharing options...
