EA82Turbo Posted September 27, 2005 Share Posted September 27, 2005 Hi, OK, this is gunna sound like a silly question! How can I check if I have a rear LSD in my Leone? Hayden Link to comment Share on other sites More sharing options...
Turbone Posted September 27, 2005 Share Posted September 27, 2005 Get down underneath the back of your car and wipe the tag clean thats on the back of the diff (most the time they are covered in grease and road grime). It will say LSD, 3.7 and with part #, etc. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted September 27, 2005 Share Posted September 27, 2005 The diff should have a sticker on it either saying 'LSD' in big letters and a gear ratio, or just the gear ratio. Another way if you have the rear of the car off the ground is to spin one tire. If the tire on the other spins the same way, you have an LSD. If the other tire spins the opposite way, it's an open-differential. If it's anything like my cars, you'll have to clear a bunch of crud to read the sticker edit: got beat to it Link to comment Share on other sites More sharing options...
Dr. RX Posted September 27, 2005 Share Posted September 27, 2005 Look at my avatar picture. Link to comment Share on other sites More sharing options...
EA82Turbo Posted September 27, 2005 Author Share Posted September 27, 2005 OK. I'll try the sticker but I use this car as a rally car and it may be wore off. Are you sure the wheels we spin the same way if the back if lifted on the ground? Doesn't the diff only lock under load, otherwise it acts like a open-diff? Hayden Link to comment Share on other sites More sharing options...
Dr. RX Posted September 28, 2005 Share Posted September 28, 2005 OK. I'll try the sticker but I use this car as a rally car and it may be wore off. Are you sure the wheels we spin the same way if the back if lifted on the ground? Doesn't the diff only lock under load, otherwise it acts like a open-diff? Hayden Yes, if they spin the same way, it is a LSD, if they spin opposite, it is an open diff. Link to comment Share on other sites More sharing options...
