Andyjo Posted September 28, 2005 Share Posted September 28, 2005 I was talking to Austin the other day about this, putting an LSD in an impreza, and it was concluded that the newer foresters all have lsd's(?) and that they would most likly fit in an impreza.... If i could find a wrecked newer forester.. and rip the diff out... that would be good, but i'm not going to go looking for one until i know if it'll fit or not thoughts? Link to comment Share on other sites More sharing options...
Qman Posted September 28, 2005 Share Posted September 28, 2005 Same platform. It will fit. It will do nothing for offroad. You need a LSD not a VLSD. Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2005 Share Posted September 28, 2005 I'm running a WRX rear LSD in my '95 that has a 4.11 RS tranny. Basically, you can run any rear subaru EJ differential you want as long as you use the ring + pinion from that transmissions drive axle. Link to comment Share on other sites More sharing options...
Freddie Posted September 29, 2005 Share Posted September 29, 2005 You could weld the rear diff.. you will just have to change your driving habits to accomodate for wide turns Link to comment Share on other sites More sharing options...
dpoppeli Posted September 29, 2005 Share Posted September 29, 2005 Do explain. It seems like even VSLD would be worlds better then open differential? Same platform. It will fit. It will do nothing for offroad. You need a LSD not a VLSD. Link to comment Share on other sites More sharing options...
