How to get at Legacy electric antenna
OK, I've picked up a used, but in good condition electric antenna from the salvage yard last night. Only problem is they are closed for 2 weeks. How do you got to electric antenna behind the fender on a legacy wagon (I'm replacing because it has been snapped clean off at the body)? I have the written instructions for replacement from there.
Carefully remove the paneling from the inside. After that it should be pretty obvious. Good luck with it.
'96-'99 Legacy wagon?
