kimkathan Posted September 30, 2005 Share Posted September 30, 2005 OK, I've picked up a used, but in good condition electric antenna from the salvage yard last night. Only problem is they are closed for 2 weeks. How do you got to electric antenna behind the fender on a legacy wagon (I'm replacing because it has been snapped clean off at the body)? I have the written instructions for replacement from there. Link to comment Share on other sites More sharing options...
edrach Posted September 30, 2005 Share Posted September 30, 2005 Carefully remove the paneling from the inside. After that it should be pretty obvious. Good luck with it. OK, I've picked up a used, but in good condition electric antenna from the salvage yard last night. Only problem is they are closed for 2 weeks. How do you got to electric antenna behind the fender on a legacy wagon (I'm replacing because it has been snapped clean off at the body)? I have the written instructions for replacement from there. Link to comment Share on other sites More sharing options...
mwatt Posted September 30, 2005 Share Posted September 30, 2005 OK, I've picked up a used, but in good condition electric antenna from the salvage yard last night. Only problem is they are closed for 2 weeks. How do you got to electric antenna behind the fender on a legacy wagon (I'm replacing because it has been snapped clean off at the body)? I have the written instructions for replacement from there. '96-'99 Legacy wagon? Link to comment Share on other sites More sharing options...
