kevinL Posted September 30, 2005 Share Posted September 30, 2005 I have a '99 ob wagon 5 speed that has developed a creak when depressing the clutch especially bad when engine is warm and in heavy stop and go traffic. Creak is definitely coming from the engine compartment. Also noticed that sometimes when engine is warm and used clutch a lot the peddle "sticks" in down position when depressed and doesn't want to return to return. All is ok when engine is cool? Any ideas? Slave cylinder? Link to comment Share on other sites More sharing options...
Setright Posted October 1, 2005 Share Posted October 1, 2005 The shaft that the clutch throw out bearing slides on needs lubrication. If you remove the intake/air filter box, then detach the clutch cable - or slave cylinder, and remove the rubber boot around the clutch fork you will gain access. It's tight, but a long brush with a bit of high temp grease on it (copper or lithium) should cure the creaking. Link to comment Share on other sites More sharing options...
subyrally Posted October 1, 2005 Share Posted October 1, 2005 think that might help the cricket sound coming from my clutch? mine only makes noise when my foot is lightly on the pedal, goes away when foot it into it or when completely off the pedal. The shaft that the clutch throw out bearing slides on needs lubrication. If you remove the intake/air filter box, then detach the clutch cable - or slave cylinder, and remove the rubber boot around the clutch fork you will gain access. It's tight, but a long brush with a bit of high temp grease on it (copper or lithium) should cure the creaking. Link to comment Share on other sites More sharing options...
Setright Posted October 2, 2005 Share Posted October 2, 2005 Rally, that sounds more like wear inside the bearing. The shaft I mentioned is only for sliding, no rotation on it. Link to comment Share on other sites More sharing options...
idosubaru Posted October 2, 2005 Share Posted October 2, 2005 subyrally, doesn't that suck, just when you think you got an easy solution......DANG IT!!! Link to comment Share on other sites More sharing options...
subyrally Posted October 2, 2005 Share Posted October 2, 2005 yeah, my noise is coming from the little thingamajig at the end of the clutch cable, its rattling in the clutch fork. i just need a bushing there and it wont make noise. Link to comment Share on other sites More sharing options...
jokermtb Posted January 7, 2006 Share Posted January 7, 2006 don't worry about it - just turn up the radio louder. All subs do this eventually, and it's not worth the cash or trouble to fix it..... Link to comment Share on other sites More sharing options...
cookie Posted January 7, 2006 Share Posted January 7, 2006 the sticking down usually means its time for a new slave and or master cyl. You can get by bleeding it for a while but there is a TSB on this. Link to comment Share on other sites More sharing options...
