sregor13 Posted October 2, 2005 Share Posted October 2, 2005 Pull the enigine on my GL becasue the Clutch would not engage. There was a clip missing on the Throwout Bearing retainer and the pressure plate is bent inward. When you loosen the bolts the Pressure Plate prongs return to there proper position. However when you go to tork down the bolts they bend back in. Anyone know why this might be happening? Thanks Link to comment Share on other sites More sharing options...
Qman Posted October 2, 2005 Share Posted October 2, 2005 Pull the enigine on my GL becasue the Clutch would not engage. There was a clip missing on the Throwout Bearing retainer and the pressure plate is bent inward. When you loosen the bolts the Pressure Plate prongs return to there proper position. However when you go to tork down the bolts they bend back in. Anyone know why this might be happening? Thanks Either the clutch disc is spent or the plate has lost tension. Either way it sounds like it is time for a new clutch set. Or, have you had the flywheel turned lately? Link to comment Share on other sites More sharing options...
sregor13 Posted October 2, 2005 Author Share Posted October 2, 2005 Well it is a brand new clutch. Sounds like it might be ruined then huh? The tension seems to be there only when the clutch is loosened. Link to comment Share on other sites More sharing options...
Ross Posted October 3, 2005 Share Posted October 3, 2005 The pressure plate fingers should do what you describe, thats no problem. You sure you've got the correct parts for your model? Link to comment Share on other sites More sharing options...
