WJM update...
I will post Dyno graph....i just have not had time to pull it.
bushings? Work is not going well....therefore if I ordered bushings, by the time they come in, I wont be there, so no one would get them.
Dyno charts, Oooohhh! You should post that in it's own thread. Air-Water intercooler dyno tested. I really like your air/fuel ratio. How did you establish that so even and rich across the rev range? Did you do something to add fuel or is that stock setting?
Also, what's the hiccup at 5900rpm?
thats the stock A/F...the wideband only reads 10:1 as its lowest value....its PIG rich.
Im not back...just this thread.
otherwise, i posted this in the AWIC thread that I have.
the Engine Control System is stock. I have done nothing to modify that.
bone stock the A/F's are like that.
at 5900 its a loss in tach signal from the Dyno.
