rguyver Posted October 15, 2005 Author Share Posted October 15, 2005 simple this was a lot easyer , and i get a extra benifit with the smaller tank when the big tank gets below 1\4 tank and i cornered hard i would run out of fuel for a second , this way the little tank will only drop for a second and not starve the engine of fuel , the older Subie gas tanks have no baffels to prevent this . i have built several custom fuelcells for other cars but i didnt want to put it in the box and the under box tank needs a hump for the diff , too much work Link to comment Share on other sites More sharing options...
carfreak85 Posted October 17, 2005 Share Posted October 17, 2005 What steering rack are you using with the XT6 hubs? I would like the 5 lug hubs for my wagon, and was wondering how difficult it would be to reproduce these parts. Link to comment Share on other sites More sharing options...
rguyver Posted October 20, 2005 Author Share Posted October 20, 2005 Im using the WRX rack , that is shortened at the inner tirod ends and some saddle mods to get it to fit porperly for the ujoints , but the stock rack works with the XT6 nuckles you just have to use the XT6 outer tirods , you may have to rethred and shorten the inner tirods too , there are lots of slightly difrent stering wracks they used over the years 80-90 , power or non . Link to comment Share on other sites More sharing options...
Subi81 Posted October 21, 2005 Share Posted October 21, 2005 Nice job, very clean Link to comment Share on other sites More sharing options...
Tbird Man Posted October 25, 2005 Share Posted October 25, 2005 any problems with bump steer? I know that is usually an issue with shortened/lengthened tie rods. or is the rack the same size just the ends different? Link to comment Share on other sites More sharing options...
rguyver Posted October 25, 2005 Author Share Posted October 25, 2005 any problems with bump steer? I know that is usually an issue with shortened/lengthened tie rods. or is the rack the same size just the ends different? Ya just diffrent rod ends . Link to comment Share on other sites More sharing options...
carfreak85 Posted October 27, 2005 Share Posted October 27, 2005 Im using the WRX rack , that is shortened at the inner tirod ends and some saddle mods to get it to fit porperly for the ujoints , but the stock rack works with the XT6 nuckles you just have to use the XT6 outer tirods , you may have to rethred and shorten the inner tirods too , there are lots of slightly difrent stering wracks they used over the years 80-90 , power or non . I was wondering because I want to speed up my steering. The FSM says the stock EA81 power steering rack is four turns lock to lock. Just looking for something closer to 3 turns. Link to comment Share on other sites More sharing options...
