82 GL wagon failed emissions :( help?
Hi-
hubby took the wagon through emissions today and it failed here are the readings:
HC co
cruise limit 180 1.3
cruise emissions 60 .24
cruise result PASS PASS
Idle limit 220 1.2
Idle emissions 140 2.54
Idle result Pass FAIL
I can post the other data if needed.
Are there errors codes that we can check, and if so is it done by turning the ignition 3 times and then watching for some flashes, or is it done another way?
Also, Hubby had forgotten to change the oil before testing it-- this car has been sitting for 3 years until we purchased it and replaced the distributor and bought a key for it. We had replaced the air filter plugs, and put in new gas.
Would the oil change make a big difference or is there something else amiss too?
Any help or advice would be appreciated--
Thanks!
Susie
An oil change will make a differnce, especially on a car that has been sitting around a few years. Chnage the oil, take it a nice highway spin and clean all the crap out of the engine. Also look into a new O2 sensor.
I hear people have good luck with something called sea foam. Also i bet you the catalytic converter is shot drom sitting around for 3 years.
nipper
Your best bet is to take it to my favorite emissions guru next to the 6th Ave. South emissions testing place in South Seattle (just south of Spokane St.). $40 plus tax if he can adjust it to pass; no charge if it doesn't pass. Plus if it needs a part he can tell you what it needs and then bring it back to him for "tweaking." You can't go wrong! PM me with a 'phone number if you need more information. Judging from the numbers, it's close and will likely just need tweaking.
