baccaruda Posted October 9, 2005 Share Posted October 9, 2005 My friend Sasha's car (1995 Legacy, 2.2, 5MT) is having intermittent episodes of poor performance. She has had the codes read and cleared twice, and they were the same both times: PO115 Coolant Temperature Sensor PO120 Throttle Position Sensor PO325 Knock Sensor #1 Malfunction PO125 Insufficient Temp Forced Loop PO133 O2 Signal Slow Banks #1 Sensor #1 (P1200 or P1700 - Mechanic has bad handwriting) Signal to TCM Circuit She has had the battery and alternator checked, per my initial advice. I am going to look at the groundwires and the alternator's wiring harness later this week. I don't know if we should suspect the computer, but I am not inclined to suspect the actual sensors named by the codes. I would appreciate any advice. Link to comment Share on other sites More sharing options...
nipper Posted October 9, 2005 Share Posted October 9, 2005 Just out of curisoty, when was the last time the O2 sensors were serviced? The care computer has an open loop and a closed loop. Open loop is when you first start the car. Untill all the opertaing parts and seinors get all to thier happy temperitures, the car is running off a fixed program. Once the car warms up, it goes into a closed loop. This is where the car is reading all the sensors and everything has reached its operating temps. The three things that can screw this up are, a bad coolant temp sensor, a bad o2 sensor, and maybe a bad tps. I dont think a bad TPS would throw it into a forced loop. so i would check out the other two first. With a good manual and a ohm meter, all three can be tested. nipper Link to comment Share on other sites More sharing options...
baccaruda Posted October 23, 2005 Author Share Posted October 23, 2005 thanks! she just had the CTS changed and it seems to have done it. Link to comment Share on other sites More sharing options...
nipper Posted October 23, 2005 Share Posted October 23, 2005 YAY! good deal nipper Link to comment Share on other sites More sharing options...
