mnewman0 Posted October 10, 2005 Share Posted October 10, 2005 I'm baffled about this one ... Car was running great, no issues. Did 3 things to it. 1. Changed the Oil 2. Replaced the air filter 3. Added fuel injector cleaner to a full tank of gas ... Now, the car will turn over and run for like 5 seconds, then the rpms dip down and it shuts off. I can keep it running, only if I start it and then immediately keep my foot on the gas petal ... keeping the rpms above 3K, but the engine doesn't sound so great when I do this. What I've done so far which has made no impact. Changed the fuel filter, checked the oil levels, filter ... all fine, no leaks, disconnected the battery for 15 minutes, to try and reset the computer. Any ideas??? Link to comment Share on other sites More sharing options...
BigMattyD Posted October 10, 2005 Share Posted October 10, 2005 Check two things: that all the hoses are connected to the air intake, and that none have come off and not been replaced. also check that the electrical connecter to the MAF (the square box) is connected. Matt Link to comment Share on other sites More sharing options...
tcspeer Posted October 10, 2005 Share Posted October 10, 2005 I agree with Matt, most likely the big hose on bottom of the the thing that connects the air filter box to the big black thing that sits near the back on top of engine. the hose or line is around 5/8 in diam. Link to comment Share on other sites More sharing options...
Skorzen Posted October 10, 2005 Share Posted October 10, 2005 I had exactly the same issue after changing the air filter, and as the previous two post suggest it is most likely the hose that connected to the air intake. I would bet money that this is the issue. Link to comment Share on other sites More sharing options...
cookie Posted October 10, 2005 Share Posted October 10, 2005 but here is another vote for a hose off. Link to comment Share on other sites More sharing options...
Setright Posted October 11, 2005 Share Posted October 11, 2005 Yep, it's the idle air hose that everyone is talking about! I did this too. Scared the wits out of me! Link to comment Share on other sites More sharing options...
mnewman0 Posted October 11, 2005 Author Share Posted October 11, 2005 Guys, Thanks for the advice!!! You guys nailed it! Link to comment Share on other sites More sharing options...
BigMattyD Posted October 11, 2005 Share Posted October 11, 2005 I can only say that I was lucky enough to be the first member to post the correct answer to this question, not that I am the smartest man in the universe or the greatest diagnostician of all time... Glad it's fixed. I can bet you were about to beat yourself up for screwing up your car during simple, routine maintenance. Matt Link to comment Share on other sites More sharing options...
FamilyShoping Posted January 4, 2012 Share Posted January 4, 2012 Thank you, It was cold today and im bringing to kids to school. The car starts then cuts off, after about 10 attempts. I bring a shop light ou,t thinking it will warn up the motor. After setting it up, wind howling, I realize this is rediculus. My gas was low, I call AAA they bring gas. $5 Same thing will not start. Guy says we can send I tow truck and tow it to the shop. I say not now let me check the internet. ( thinking this is a 1999 subaru with 135,000 miles, I was thinking about trying for 200,000, but maybe I should get a new car) I find this blog, check the hoses, no, but one of the clips on the air filter is the wrong way leaving a 1/2 inch gap. I fix the clip. Subaru starts right up. Back on the road. Thank you Again, Go Subaru. Link to comment Share on other sites More sharing options...
BigMattyD Posted January 4, 2012 Share Posted January 4, 2012 Woo Hoo! Easy fix and saved a ton of money! Great Job! Link to comment Share on other sites More sharing options...
