ea82 carb/manifold, on a ea81?
Just going by the original carb for my '82's original engine, and comparing it to the one on the engine in it now. Yes, it would be an upgrade. Old carb = Carter Weber, carb now = Hitachi, or single barrel vs progressive 2 barrel. Gotta make a difference to the + side, I would think........
the EA81 carbs were not all carter / weber's - most were in fact hitachi's similar to the EA82 version - not sure if there was any difference in the primary / secondary bore sizes, but there was a feedback version, and a non-feedback version. The EA82 only got the feedback type I think. Anyway - if your going to all that trouble, you might as well drop in the SPFI from an EA82 instead. You just have to make slight mods to the EA82 disty, and grab the ECU and wire it all up.
