soobscript Posted October 12, 2005 Share Posted October 12, 2005 Some part #s for reference. All is quoted from the sheet in the box. Typo's are courtesy of FHI although I already fixed some. Sorry about the formatting. SUBARU X1041AA014 ENG GASKET & SEAL KIT This Engine Gasket & Seal kit applies to 1.8L (for MPFI & Turbo) models of 1985MY and after and consists of the following component parts. Line # Part # Part Name Q'ty 1 11832 AA002 GASKET, OIL SEPR COVER 1 2 8067 76011 OIL SEAL, 76 x 93 x 10 1 3 8039 26020 GASKET, 26.2 x 31.5 x 1 4 4 8039 14030 GASKET, 14.5 x 20 x 1.2 1 5 11071 AA000 "O" RING, CYL BLOCK 1 6 8067 38070 OIL SEAL, 38 x 59 x 9 1 7 8069 10110 "O" RING, 10 x 2 1 8 15261 AA000 GASKET, AIR BREATER 1 9 11044 AA013 GASKET, CYL HEAD 2 10 8039 12030 GASKET, 12.5 x 18 x 2 2 11 8053 22010 CIR CLIP, IN 22 8 12 13089 AA010 "O" RING, 12 x 1.9 2 13 8069 58020 "O" RING, 58 x 2 2 14 13210 KA000 COLLET, VALVE 16 15 13272 AA001 GASKET, ROCKER COVER LH 1 16 13270 AA001 GASKET, ROCKER COVER RH 1 17 13271 AA003 WASHER, ROCKER COVER 9 18 13591 KA000 MOUNT CP, BELT COVER 7 19 21116 AAA001 SEARING, WATER PUMP 1 20 13588 AA000 SEARING, BELT COVER 1 21 11121 AA001 GASKET, OIL PAN 1 22 11126 AA000 GASKET, DRAIN PLUG. 1 23 15066 AA000 GASKET, OIL PUMP BODY 1 24 8069 45020 "O" RING, 45.7 x 2.4 1 25 11072 AA030 GASKET, THERMO HOUSING 1 26 21114 AA000 GASKET, WATER PUMP 1 27 8039 10050 GASKET, 10 x 14 x 1 4 28 8039 12040 GASKET, 12 x 16 x 1 2 29 14035 AA160 GASKET, INTAKE MANIFOLD 2 30 16175 AA070 GASKET, THROT CHAMBER 1 31 44022 GA330 GASKET FOR MPI 2 32 44022 GA340 GASKET FOR TURBO 2 33 13207 KA001 SEAL, INT 4 34 13211 AA030 SEAL, EXH 4 35 13583 AA040 SEALING, BELT CVR RH 1 36 13585 AA000 SEALING, BELT CVR LH 1 37 13581 AA000 SEALING, BELT CVR FR 1 38 13582 AA000 SEALING, BELT CVR RR 1 39 14073 AA040 GASKET - WAT PIPE #2 1 40 14072 AA050 GASKET - WAT PIPE 1 41 16608 AA000 SEAL - FUEL INJECT 4 42 14468 AA010 GASKET - AUX AIR VLV 1 43 14072 AA060 GASKET - WAT PIPE 2 44 14035 AA170 GASKET - COOL 2 45 8067 38040 OIL SEAL - 38 x 55 x 9 2 Other stuff I got: 44022 GA210 GUSKET T INLET 1 exhaust gasket, up-pipe to turbo 44022 GA220 GASKET T OUTLET 1 exhaust gasket, turbo to down-pipe 44022 GA191 GASKET 1 exhaust gasket, down-pipe to cat 15020 AA011 SPR-RELIEF VALVE 2 oil relief valve spring (cam tower) 30539 AA000 CLIP-CCH SLEEVE 2 clutch release bearing retaining clip 45161 GA490 HOSE RAD IN 2 radiator hoses (same top & bottom) 15010 AA016 PUMP ASSY - OIL 1 oil pump with pressure sender X2111 AA017 W/PUMP GASKET KIT 1 water pump with gasket and o-ring Link to comment Share on other sites More sharing options...
hooziewhatsit Posted October 12, 2005 Share Posted October 12, 2005 *select all, copy, save* Thanks for the huge list. I'm sure it will be very helpful someday. Link to comment Share on other sites More sharing options...
xoomer Posted October 12, 2005 Share Posted October 12, 2005 hooziewhatsit said: *select all, copy, save* Thanks for the huge list. I'm sure it will be very helpful someday. PRINT!!! Its going in my shop (along with a laptop with the FSM) Link to comment Share on other sites More sharing options...
WJM Posted October 17, 2005 Share Posted October 17, 2005 "engine gasket kit" gasket kit gaskets EA82T EA82-T engine gasket stuff kit kits engines gaskets kits.....stuff for EA82T Sorry, jsut for the search engine. good job posting all that. Link to comment Share on other sites More sharing options...
