Clutch noise
I have a problem....When I drive my car and change gears, when the clutch pedal is push, a sound like you scratch with a sprig an arc tight as a drum.
I don't now if my explanation is enough but if you have something ambiguous I will try to give more details.
Thanks.:confused:
mine sounds like a cricket when your foot is lightly on the peddle, i think there is supposed to be a rubber bit on the end of the cable surrounding hte ball thingy, but eithe way, thats what makes the noise in my car, it rattles in the fork. annoying as hell.
sounds like a throw out bearing or a pilot bearing. Mine has made noise both times they've gone out
Please can you tell me more exactly because I don't nou all expressions from englisg tongue.
Thank you verry much in advance.:)
