tommygun Posted October 13, 2005 Share Posted October 13, 2005 my 87 gl wagon wont fire up. tested voltage at fuel pump got 0 volts. have 12 volts dc across fuse contacts. tore into dash looking for fried wire harness or bad relay. no such luck. im as confused as the guy who wrote this repair manuel, any help appreciated Link to comment Share on other sites More sharing options...
Bobby_boucher Posted October 13, 2005 Share Posted October 13, 2005 I would trace the wiring back through everything, i mean start at the pump and slowly work your way forward until you get voltage. Link to comment Share on other sites More sharing options...
zyewdall Posted October 13, 2005 Share Posted October 13, 2005 I would trace the wiring back through everything, i mean start at the pump and slowly work your way forward until you get voltage. Easier way to to do it is to run a new wire from the proper fuse (and relay if appropriate) back to the fuel pump. Disconnect the end of the old one in case it is shorted somewhere, and put a tape label on it so you don't confuse yourself again later... Link to comment Share on other sites More sharing options...
Sweet82 Posted October 13, 2005 Share Posted October 13, 2005 Have you checked your fuel pump control unit? I assume 87's had them. My FPCU went out and it was giving me fits trying to fix a fuel pump that wasn't broke. Good Luck, Glenn 82 SubaruHummer--new FPCU 84 GL 01 Forester Link to comment Share on other sites More sharing options...
canajun2eh Posted October 13, 2005 Share Posted October 13, 2005 The fuel pump isn't supposed to see constant 12 volts. The fuel pump relay is energized when the ignition switch is in the "start" position and also when the engine is running. "Engine running" is defined as the pump controller or ECU seeing tach pulses. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted October 13, 2005 Share Posted October 13, 2005 you should also be able to connect the green test connectors, turn the key to on, and the fuel pump should cycle on-off every second or two. There should also be a relay/solenoid under the hood that clicks on & off also. If you don't have voltage at the pump after doing that test, then you can continue to check the Fuel Pump Control unit & wiring. good luck Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 14, 2005 Share Posted October 14, 2005 First quick test: pop the distributor cap off and see if the rotor is turning when the engine is being cranked. If the rotor isn't turning, the pump won't be told to run. Link to comment Share on other sites More sharing options...
