Sounds like 02 Outback has a turbo...
Hi all,
First, thanks for the wealth of knowledge this forum has been for me. I just purchased my first subie, an 02 Outback 4cyl AT about 3 months ago. I do love it so.
Here is my issue. when accelerating normaly every thing sounds perfect. When I floor it however the engine developes a loud sqeal/whine/howl. Almost as if a belt is slipping. I figured I would post here first before heading to the dealership and breaking out the wallet. Any help would be much appreciated.
Thanks
Shane
I wouldn't go to the dealership first off. That's big money and basic diagnosis could be done by a local shop for cheaper. Does the engine have to be under load, i.e. moving the car to make the squeal or can you reproduce it by revving it hard in Park? If you can, open the hood and listen while you pull on the throttle cable or a friend runs the pedal. Watch out for fans/moving bits and see if you can pinpoint the sound.
  Setright said:
Engine off.
Check for loose belts and have a closer look for cracks.
Cracks where? in the belts, or somewhere else.
Thanks
Shane
Changed the oil for the first time last night... Muuuuch easier than my old civic. So nice having the filter on the bottom istead of halfway up the back of the engine.
  shaner said:
Hi all,
Thanks
Shane
Check the airbox - it's kinda easy to not clip the bottom of it back in place well - causing an air leak and noise.
Also, is there a difference between the noise based on whether the A/C or defroster is on? maybe the a/c clutch bearing is going bad.
just some guesses
I checked the airbox, and it was sealed well. However the intake tube in general is very loose at most of the joints. Also a .5 diamiter hole has been drilled in the rear of the main flatter part of the intake that is behind the grill. Does anyone else have this hole?
I wonder if air is getting sucked in at a loose point at certian rpm's.
Time to play with some hose clamps. :)
Thoughts?
Thoughts?
If you mean drilled as in not original, I'd try putting some tape over it and see if the noise goes away. It could be a normal hole for water drainage or something if its factory original.
I dunno.
