TurboXT Posted October 14, 2005 Share Posted October 14, 2005 Ok, so I am lazy....that is the reason for this post/trial. Just had to say this. So I did an auto to manual swap on my 84' GL Brat.....and I decided to leave the front sway bar off (insert bit about being lazy here), I really didn't notice a difference in handling at first, but the more I was looking for it, the more I saw just a little bit more body roll. I thought from other people's comments, and opinions that it would be un controlable and not to do it. I am not sure how fast I was driving, but I have to say I have done at least 55mph so far, and it's really not that bad. And as for articulation, it is quite a bit better...I think it's worth not having the sway bar on there for the added articulation. HOWEVER, I am not sure what the car is going to be like at say, 60mph and above (ok fine, up to 80) then it might be a little different, and harder to control. Thought I would post to see if anyone else has taken their sway bar off, and how it responds at higher speeds....to find the TRUTH about sway bar removal. Rick Link to comment Share on other sites More sharing options...
PeterD Posted October 14, 2005 Share Posted October 14, 2005 well a vw suspention company... Shine Racing has a setup for my rocco that dosn't require a sway bar. just a rear sway bar. its not uncomon. would a properly setup car not need a swaybar.... or would the suspetion be to stiff for daily use. Link to comment Share on other sites More sharing options...
calebz Posted October 14, 2005 Share Posted October 14, 2005 TurboXT said: to find the TRUTH about sway bar removal. Rick The truth is, with my coilovers and 20mm sway bars, my wagon handles like a friggin go kart Without the bars.. its not dangerous, but there is noticeably more body roll. Link to comment Share on other sites More sharing options...
torxxx Posted October 14, 2005 Share Posted October 14, 2005 I cut out my sway bar on my wagon 2 years ago. I like the way it rides now. Less chatter in the front end on gravel, less understeer, more independent fron suspension. I've rallied the crap out of this car like that. Burned up 3 sets of tires last year on the ice track. I may put a sway bar back on but it'd have to be detachable for offroad use. Even with my 4" lift on I still do 65 - 70 down the highway and the body lean isnt any worse than my old ladys 96 Isuzu Rodeo Link to comment Share on other sites More sharing options...
Numbchux Posted October 14, 2005 Share Posted October 14, 2005 I've done many a long freeway trip in my 4" lifted, swaybarless wagon. They're DEFINATELY optional. there's one bridge on 35 where I usually drive that goes diaganolly, so the front tires don't hit the expansion joint at the same time. it's a little scary at 80+, but not enought that I worry about it. Link to comment Share on other sites More sharing options...
bushbasher Posted October 14, 2005 Share Posted October 14, 2005 if you take off the front and leave the rear on (if you have a rear one) then it will be more prone to oversteer when the throttle is lifted, which is not good at highway speeds doing an emergency manouver. otherwise it just handles worse but still controllable. You'll notice if you are driving the car down the road and toss it side to side like a slalom its easier to get the car upset with the sway bars off, even though outright grip in a corner isnt really reduced that much. I think off-road handling gets better with the sway bar off because in this case body lean and weight shift is less important than maintaining wheel contact on uneven ground. Link to comment Share on other sites More sharing options...
nkx Posted October 14, 2005 Share Posted October 14, 2005 calebz said: The truth is, with my coilovers and 20mm sway bars, my wagon handles like a friggin go kart XT6 swaybars?? Link to comment Share on other sites More sharing options...
Ross Posted October 14, 2005 Share Posted October 14, 2005 They make 'em handle better, but without them it'll still handle a heck of a lot better than, say, a 40 series landcruiser! None of them have any swaybars at all. Link to comment Share on other sites More sharing options...
colossal_monstrosity Posted March 6, 2006 Share Posted March 6, 2006 1: Where/how do you get COILOVERS for the old wagons? 2: Some of the EA82's didn't come with swaybars? Expand on that - how do I add one? Link to comment Share on other sites More sharing options...
calebz Posted March 6, 2006 Share Posted March 6, 2006 colossal_monstrosity said: 1: Where/how do you get COILOVERS for the old wagons? 2: Some of the EA82's didn't come with swaybars? Expand on that - how do I add one? The coilovers I used were ebay aftermarkets made for a WRX Every EA82 I have seen came with at least a front swaybar. I used XT6 front and rears for my wagon, but I had an advantage. Mine is the only wagon I have ever seen that actually had a factory rear bar on it.. granted, it was wimpy, but the mounts are the same as the 20mm bar Link to comment Share on other sites More sharing options...
kingbobdole Posted March 6, 2006 Share Posted March 6, 2006 Link to comment Share on other sites More sharing options...
baccaruda Posted March 6, 2006 Share Posted March 6, 2006 kingbobdole said: Link to comment Share on other sites More sharing options...
uncoolperson Posted March 6, 2006 Share Posted March 6, 2006 pulled mine out last week, and all I can say is in town speed turns are really fun now... Link to comment Share on other sites More sharing options...
operose Posted March 6, 2006 Share Posted March 6, 2006 phil stole my stolen zombies!! Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted March 6, 2006 Share Posted March 6, 2006 uncoolperson said: pulled mine out last week, and all I can say is in town speed turns are really fun now... I wondered how that turned out Link to comment Share on other sites More sharing options...
Sweet82 Posted March 6, 2006 Share Posted March 6, 2006 It certainly makes the car feel a bit unstable. Low speeds are where I have noticed it most. The car seems more grabby in a corner w/o the bar. My.02 Glenn 82 SubaruHummer 84 GL Mad Max 01 Forester Link to comment Share on other sites More sharing options...
