operose Posted October 18, 2005 Share Posted October 18, 2005 So...3.89 gears?not..3.90 gears? What's a tenth anyway... Watching, Wondering, Waiting how this will all turn out... Developing a Locker would be a major step forward for Subieists. Keep on Raging! Glenn 82 SubaruHummer--welded 84 GL Mad Max--open 01 Forester--Limited I think it would be a major step as well... I'm contemplating just throwing in a 4.11 tranny as there are _TONS_ of audi locking rear diffs with this gear ratio.. but I refuse to give up my locking center.. Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted October 18, 2005 Share Posted October 18, 2005 Could the 3.89 to 3.90 difference be made up in tire size? Hummm..... Quote Link to comment Share on other sites More sharing options...
operose Posted October 18, 2005 Share Posted October 18, 2005 Could the 3.89 to 3.90 difference be made up in tire size? Hummm..... not with AWD.. that's bad for it I guess... Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted October 18, 2005 Share Posted October 18, 2005 I'm saying use different size tires to compensate for the difference so the system won't know the difference? Quote Link to comment Share on other sites More sharing options...
operose Posted October 18, 2005 Share Posted October 18, 2005 I'm saying use different size tires to compensate for the difference so the system won't know the difference? I suppose that's possible, yes.. not sure I'd want to go that route though.. I'm wondering if I can just put the gears from my diff into the housing for the audi.. but I still have to take them apart and see what's what Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 18, 2005 Share Posted October 18, 2005 If you ran it offroad it wouldnt matter at all really. Any bind up in the drive train would slip free due to the loose terrain. Lots of offroad vehicles run different gear ratios between front and rear diffs. Quote Link to comment Share on other sites More sharing options...
operose Posted October 18, 2005 Share Posted October 18, 2005 If you ran it offroad it wouldnt matter at all really. Any bind up in the drive train would slip free due to the loose terrain. Lots of offroad vehicles run different gear ratios between front and rear diffs. I'm worried about streetability though.. this will be my daily driver.. Quote Link to comment Share on other sites More sharing options...
s'ko Posted October 18, 2005 Share Posted October 18, 2005 If you keep it in 2wd while on the street, you should be ok. So anyone know the spline count of the audi 3.89 rear diff and the diameter of the stub axle? How about the drive shaft input flange? This could be the start of a new revolution. Quote Link to comment Share on other sites More sharing options...
operose Posted October 18, 2005 Share Posted October 18, 2005 If you keep it in 2wd while on the street' date=' you should be ok. So anyone know the spline count of the audi 3.89 rear diff and the diameter of the stub axle? How about the drive shaft input flange? This could be the start of a new revolution.[/quote'] I have a 3.89 locking rear audi diff... but it's in the car I'm driving daily..... with regards to keeping it in 2wd, I can't, because I have an AWD xt6 Quote Link to comment Share on other sites More sharing options...
operose Posted October 18, 2005 Share Posted October 18, 2005 If you keep it in 2wd while on the street' date=' you should be ok. So anyone know the spline count of the audi 3.89 rear diff and the diameter of the stub axle? How about the drive shaft input flange? This could be the start of a new revolution.[/quote'] I can check on the diameter of the stub axle and the drive shaft input flange though... and I'm glad to know that some of you think this is a good idea as I've been throwing it around in my head ever since I started driving the audi Quote Link to comment Share on other sites More sharing options...
offroadsubaruguy Posted October 19, 2005 Share Posted October 19, 2005 as far as easy access to removing an axel, has anyone ever thought of using somethng like a hood pin design? that way u could just pull the pin and remove the axel... no more rotating of tires to get to the pin....just a thought Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted October 19, 2005 Share Posted October 19, 2005 What-you-talking-about-Willis? Could you splain? Quote Link to comment Share on other sites More sharing options...
MorganM Posted October 19, 2005 Share Posted October 19, 2005 as far as easy access to removing an axel, has anyone ever thought of using somethng like a hood pin design? that way u could just pull the pin and remove the axel... no more rotating of tires to get to the pin....just a thought Yes; I think it's Singletrack who runs cotter pins instead of spring pins. Quote Link to comment Share on other sites More sharing options...
singletrack Posted October 19, 2005 Share Posted October 19, 2005 Yes; I think it's Singletrack who runs cotter pins instead of spring pins.Hell yeah, I started using them just for the locker axle, but they work so well I just run 'um all around now. No, a spring pin is not hard to use, but they do seize sometimes or your punch breaks or gets stuck inside the pin or you whack your thumb with the hammer or..... Well, any way I just lean in there with the needle-nose, and it's done. Quote Link to comment Share on other sites More sharing options...
singletrack Posted October 19, 2005 Share Posted October 19, 2005 and I'm glad to know that some of you think this is a good idea as I've been throwing it around in my head ever since I started driving the audiIt's an f-in awesome idea. Quote Link to comment Share on other sites More sharing options...
soobme Posted October 20, 2005 Share Posted October 20, 2005 Been using cotter pins for years (I HATE ROLL PINS) and have NEVER had a problem:) Quote Link to comment Share on other sites More sharing options...
operose Posted October 20, 2005 Share Posted October 20, 2005 thanks for the cotter pin idea guys... I'll be using them all the way around so axles are easier to change now... although I've made the perfect spring pin punch Quote Link to comment Share on other sites More sharing options...
