Quick tire question
depending on if your model is 2 or 4wd, or GL or DL it will call for different sized tires. i believe the STD's called for something as small as 155's and the DL's called for 165's on the EA-81's and on the EA-82's called for 175's on the DL's and 185's on the GL 4WD.
BTW, if you can fit the tire without fender trimming, thats Pleadies' way of telling you your tires are too small
not a stupid question, do a search, there is bound to be somting about it. just put in a divorced t-case. a big lift makes this very nice. i think the minimum is about a 6inch lift. then, with the gears for the transfer case, you can run solid axles.
eye_why, is your car 2wd? because mine says i think 175/70/13 in the manual. but you could defiantley fit 185/70/13's. i ran 185/70/14 (1inch bigger) for a while and absolutly no rubbing. you'll be fine.
