Guest BFP-closed Posted September 27, 2003 Share Posted September 27, 2003 so when a turbo starts squealing ocasionally at higher RPM how long does it have to live? Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 27, 2003 Share Posted September 27, 2003 well if I were you, I'd start to look for a new turbo like very soon. Its ounds like the bearings are going out and if it flies apart while you're driving........dum dum dummmmmmm, you'll be :boohoo: Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted September 27, 2003 Share Posted September 27, 2003 Hey Russ doesnt Andrews friend have an almost new turbo for like $50? Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 27, 2003 Share Posted September 27, 2003 yeah but I think either he's gonna put it on his car or Andrew is gonna get it for his wagon. I dunno, gotta ask him Link to comment Share on other sites More sharing options...
Guest BFP-closed Posted September 27, 2003 Share Posted September 27, 2003 called u pull it they have one for $250 - thats seems like a lot!! 30 guarantee...... are they hard to replace? just hoses n bolts, right? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 27, 2003 Share Posted September 27, 2003 That's insanely expensive - go to the yard, and pull one yourself. Better yet - go to some other yard and pull one. U-Pull-It is hella expensive - even when you pull parts. Find some other yard that will wheel and deal - get one for $50 or less. GD Link to comment Share on other sites More sharing options...
Guest BFP-closed Posted September 27, 2003 Share Posted September 27, 2003 well... i called all over the place and u pull it is the only place that has ONE. I DO NOT like them - but whats a guy to do? maybe a stupid question.... can i do some modifications and put another turbo on, or maybe modify it to run without one? (though the compression would be all wacked out) just a thought..... weeeellll...... i guess im off to upullit in a bit :^( Link to comment Share on other sites More sharing options...
oddcomp Posted September 27, 2003 Share Posted September 27, 2003 now last time i was at u pullit up in portland the turbos where like 50.... hmmm perhaps i read the board wrong .. Link to comment Share on other sites More sharing options...
archemitis Posted September 27, 2003 Share Posted September 27, 2003 you would just be stuck with a gas guzzling pig without a turbo. you can get a turbo off any 80s car and switch the exhaust housing and compressor housing, and boom! turbo! any ihi will do as long as its not from a legacy, they are too big. ford probe, mazdas, ford tbirds, all kinds of turbos you can use! and the bigger one from a tbird is an upgrade Link to comment Share on other sites More sharing options...
soobme Posted September 28, 2003 Share Posted September 28, 2003 We got one down here in Medford @ the Action U-Pull it yard, I don't know what they go for. I could call them on monday and find out for ya. Link to comment Share on other sites More sharing options...
calebz Posted September 28, 2003 Share Posted September 28, 2003 Quote ford probe, mazdas, ford tbirds, all kinds of turbos you can use! and the bigger one from a tbird is an upgrade straight swap? Link to comment Share on other sites More sharing options...
Adam N.D.J. Posted September 28, 2003 Share Posted September 28, 2003 Oh no, not a straight swap. Although you can mix and match the parts. I've got a friend that built a turbo rabbit, and he's useing a turbo that consist of a Ford t-bird center senction, a GL-10 hot side, and a Legacy cold side. Another friend, on his Legacy has the Legacy hot side with the T-bird cold side. So you can build a turbo that is bigger and better without haveing to fab up different mounting flanges on the crossover. The IHI hybrid has been in the works for over a year now, and both the hybrids here work great. Although if you get just one bigger turbo, you will have to get different flanges put on, as the flange on the EJ22 crossover is quite a bit bigger than the EA82 one. You get the idea. Plus with just a plain bigger turbo, your prolly not going to make full boost untill a higher rpm, thats where the hybrids are better, they don't drastically increase the rpm which you make full boost. Hope this helps. Link to comment Share on other sites More sharing options...
Stupidru Posted September 28, 2003 Share Posted September 28, 2003 Check your turbo oil drain hose. If it becomes clogged or pinched it will make your turbo squeal...it happened to me. Link to comment Share on other sites More sharing options...
jmr052 Posted September 28, 2003 Share Posted September 28, 2003 Heck, for $150 I would pull one and ship it to ya. Seriously, mine started squealing and then a few miles later, white smoke. Can you say hello to a head gasket makeover? You really need to get on it as there is no telling how long it will last or what will happen when it goes out. Jay Link to comment Share on other sites More sharing options...
archemitis Posted September 28, 2003 Share Posted September 28, 2003 i guess the t-bird turbo is the best option for a direct swap upgrade. but it has to be the biggest one that came on the t-bird, because there were two or three different ones. and i think just about any turbo other than the stock subaru one is an upgrade, because they were all made for dohc motors that were 2.0 or bigger. just dont take any of the wheels off of the center piece, and make sure the compressor doesnt hit the aluminum housing. fun stuff:burnout: Link to comment Share on other sites More sharing options...
