bella Posted October 17, 2005 Share Posted October 17, 2005 Hello Now I have Valvoline 15W40(it has 6.000KM---is ok if I change it at 7.000Km?) and because winter is comming I will replace this with Valvoline 10w40. I must change the oil filter too? Thanks:) Link to comment Share on other sites More sharing options...
soobmater Posted October 17, 2005 Share Posted October 17, 2005 hm, that should be right, and yes, you have to change the oil filter. 10w40 should be just fine let me do some math here... if i was you, i would change it as quick as you could. Link to comment Share on other sites More sharing options...
Snowman Posted October 17, 2005 Share Posted October 17, 2005 Yes, definitely change the filter as well at that interval. Link to comment Share on other sites More sharing options...
bella Posted October 17, 2005 Author Share Posted October 17, 2005 So...interval for changing oil (in a normal drivig style) should be...??? Link to comment Share on other sites More sharing options...
zyewdall Posted October 17, 2005 Share Posted October 17, 2005 So...interval for changing oil (in a normal drivig style) should be...??? Under normal driving, I try to change it every 3,000 miles for regular (10W40 or 20W50), or 8 to 10,000 for synthetic (5W40 or 15W50). Although I also usually burn/leak about a quart every 1,200miles, so you could sort of figure I'm changing it every 6,000 just through that.... Link to comment Share on other sites More sharing options...
bella Posted October 17, 2005 Author Share Posted October 17, 2005 So my oil has 6000KM=4000 miles....and I use 1Liter/2000Km. Link to comment Share on other sites More sharing options...
