power window and dash warning lights problems
hey guys..
Got two EA82 wagons at work that I'm working on. One is a 92 loyale. The power windows do not work. Checked all the fuses, changed the drivers side switch and still doesnt work. Is there a relay somewhere or a fuseable link for the power windows somewhere that I'm missing?
The other car is a 86 carb'd wagon. A kid at work put a spfi motor in there, changed everything over and couldnt get it to run. I got it running, but the warning lights in the dash are on. The charge light, the stop lamp and the brake fluid lights are all on. I unhooked the positive cable to the battery and the car kept running, with positive hooked up it charges right at 13 volts. The brake lights work, and the brake fluid is topped off. What would be causing the warning lights to stay on. Also the kinda dim and they flicker when on, they arent bright like the warning lights in my wagon
From my experience, charging voltage should be at least 13,5 V at idle speed and no other things(lights, radio) on.......is no end of the world if at least is growing(voltage) when you accelerate.....sorry my english.
