soobme Posted October 19, 2005 Share Posted October 19, 2005 I need to get a little more lift out back, and the stock adjuster is maxed out(I'm gessing a worn out torsion bar) so I want to re-index the spring plates. Should I go up 1 or 2 splines? Do I just back out the 2 bolts in the end of the housing and pull the plate out? Or is there more to it that I'm not seeing? Link to comment Share on other sites More sharing options...
mcbrat Posted October 19, 2005 Share Posted October 19, 2005 that's what I did. just pull the plate off, and move it 1 notch only (down, towards the rear). it will give you a couple inches of lift, and make it a lot stiffer. I don't think I could have gotten it back together if I would have moved it 2 notches. Link to comment Share on other sites More sharing options...
soobme Posted October 19, 2005 Author Share Posted October 19, 2005 So am I right, just back out the 2 bolts that go into the side@ the end of the torsion housing tube and then the spring plate will slide out? Link to comment Share on other sites More sharing options...
mcbrat Posted October 19, 2005 Share Posted October 19, 2005 you have to remove the 3 bolts that hold the plate to the trailing arm as well. those are the ones that were a pain to get back in. I believe people that do it the proper way, use a jack to line them up, instead of brute arm force Link to comment Share on other sites More sharing options...
soobme Posted October 20, 2005 Author Share Posted October 20, 2005 Cool! Thanks for the info:burnout: Link to comment Share on other sites More sharing options...
