ACA Posted October 21, 2005 Share Posted October 21, 2005 Anyone have simple directions for reprogramming a keyless remote for 97 legacy? I can't find a black disarm button; the directions that came with the remote are worthless. thx Link to comment Share on other sites More sharing options...
johnphils Posted October 21, 2005 Share Posted October 21, 2005 Drivers side look up in under the dash, you will see the keyless entry brain and there will be a black wire tucked up in there with a little black button. Sometimes they are hard to find. Once you find it push and hold the button in you will hear the locks, then while still holding the button push anybody on the remote and you will hear the locks again, than let go of the little button and you are all programed. Hope this helps. ACA said: Anyone have simple directions for reprogramming a remote for 97 legacy? I can't find a black disarm button; the directions that can with the remote are worthless. thx Link to comment Share on other sites More sharing options...
forester2002s Posted October 22, 2005 Share Posted October 22, 2005 This site has lots of info about remotes: http://www.cars101.com/subaru/keyless.html#alpine Link to comment Share on other sites More sharing options...
ACA Posted October 22, 2005 Author Share Posted October 22, 2005 I've looked under the dash with a flashlight, all I see is a bunch of wires, no black button. Is it different in the 1997s? thanks Link to comment Share on other sites More sharing options...
Al_SemC Posted October 22, 2005 Share Posted October 22, 2005 I installed a keyless entry system on my '97 Outback about three weeks ago. The button is on a set of brown wires and is supposed to be installed into a square hole behind the hood release lever. Mine is black, inside a black bezel. If it isn't there, hunt down the keyless module and follow the larger wiring harness until you get two brown wires. The button should be at the end of that. Link to comment Share on other sites More sharing options...
later, Peter Posted October 22, 2005 Share Posted October 22, 2005 It's there. A kid at a tire store tried to show it to me (the first time) he was pushing on this bolt head for about a minute.... then said: "there you go". (expecting a tip???) anyway, got home got a flashlight got on my knees & squeezed into the floor board space... upper left corner back of the dash, almost against the firewall to the left of the pedals........ keep looking, the little button hangs from about 2 inches of wire but MAY be behind other wires.... The program is easy. Buy the device off the internet? Make sure the remote's #'s are correct not necessarily the year of vehicle information. Later, Peter Link to comment Share on other sites More sharing options...
ACA Posted October 25, 2005 Author Share Posted October 25, 2005 Al_SemC said: I installed a keyless entry system on my '97 Outback about three weeks ago. The button is on a set of brown wires and is supposed to be installed into a square hole behind the hood release lever. Mine is black, inside a black bezel. If it isn't there, hunt down the keyless module and follow the larger wiring harness until you get two brown wires. The button should be at the end of that. I finally found the button--at the end of 2 brown wires neatly tucked up behind the module; had to clip a plastic tie to get to it. Reprogramming was easy. Thx for the tip. Link to comment Share on other sites More sharing options...
Al_SemC Posted October 25, 2005 Share Posted October 25, 2005 Well, gee...why would they ever follow the directions straight from Subaru and install the programming button where it's supposed to go? Link to comment Share on other sites More sharing options...
