EJ22 questions.. 1989-1994
Alright guys, I'm starting to get into EJ22's at work now. Popped my newer generation cherry this week at work. My questions are:
1. Ej22's dont have a led light on the ecu that spits codes does it? If not, what OBD thing do I need to get codes off it?
2. What are the years are far as the wiring harness's go? I pulled a motor from a 90 legacy wagon yesterday and put it in a 92 legacy sedan and I had to change the intakes and a few other things to get the wiring harness's to line up. I'm assuming 89-91 and then 92-94 are the differences in years?
3. As for the dual cooling fans, is one of them supposed to come on when I start the car? or are they both thermo sensor'd?
thanks in advance for some answers...
Under the kick panel on the driver's side you will find two single pole connector sets. One is green, and the other black. The black one puts the ECU in diagnostic mode. Connect these and turn the ignition on, and read the code from the CEL on the dashboard. Long flashes are tens and short ones are 1's.
In 92 the connectors for the on-engine wiring harness were changed from the ols style of three connectors to the new style with two. Also in this year, they changed from the grey injectors to the red ones. Not sure on the specifics on how they differ. . in 95 they moved all the connectors to the right rear of the engine and put all of the connections that are behind the TB into them, so you only have to disconnect these to have all of the wires from the engine disconnected. In 97 they also went to solid adjustable lifters, dropping the hydraulic lash adjusters, and making all of the engines interference type, (89-96 were non-interference)
The fans act as stated abobe, and are controlled by the ECU (IIRC) based on coolant temp taken at the crossover pipe. You will find two coolant temp senders there to the right of the throttle body (if looking from the drivers seat). The one with two wires is for the ECU, and the single wire one is for the instrument cluster. . .
Hope this helps with your questions.
The 90-91 Legacies & 92-94 legacies do have some differences. The electrical harness between the two are different. As you noticed, the 92 engine harness won't plug into the 90-91. There are a few other things here and there, but for the most part things are pretty similar.
Do check out the legacycentral bbs. A lot of good info on there.
Hmm...that's weird (see my post above about my 92-89 compatibility). I got all my parts from Canada, so maybe they used the same connectors and everything on the Canuck cars throughout those years but changed it in the US.
Maybe its the metric electricty vs. the english electricity :lol: (damn that guy looks evil)
There may be some polution controls that are in the US cars that arent in the candain models, henc some differnces.
nipper
nipper
LOL, just like the electrons in a diesel rig are green, whereas the electrons in a gas rig are blue. (Sorry, old joke in the auto-diesel department at UAA:rolleyes: .)
