RX Leone LSD Diff.
I've sourced an RX Leone rear diff (not recently, ages ago), yes its 4.11 LSD from an Automatic RX Turbo. Now I wanna to know if I could change the crown from 41 teeth down to 37 teeth to match the AWD gearbox. Can it be possible to do that myself at home? or do I require special tools? Will the bolt holes fit? (I'm getting the 37 teeth crown from an 89 L series wagon) as my rear diff that I'm suspicious that is worn out as it makes whine noises, and while I am changing the crown over, is there any notices that I should do while its taken apart ie. New seals etc?
Thanks
AP
