justy code 33
-88 justy Gl carbbed
I pulled the codes out of the ECU 'cause the CEL light comes on randomly while driving. The car sometimes has trouble starting even though the choke works right, and tends to hesitate for a bit when I try to accelerate. Does anybody have an FSM or something so they could tell me what a code 33 for my car means? Thanks guys.
Subaru ECU Codes
  Quote
-- 1984 Through 1988 Carbureted Models --
CODE PROBABLE CAUSE
11 Ignition Pulse System
22 Vehicle Speed Sensor (VSS) or Circuit
23 Oxygen Sensor
24 Coolant Temperature Sensor or Circuit
25 Coolant Temperature Sensor (1984 Models)
25 Manifold Vacuum Sensor or Circuit (1985-1988 Models)
32 Duty Solenoid Valve or Circuit
33 Main System in Feedback
34 Back Up System
42 Clutch Switch or Circuit
52 Solenoid Valve Control System
53 Fuel Pump or Circuit
54 Choke Control System
55 Upshift Control
62 EGR Solenoid Valve Control
63 Canister Solenoid Valve or Circuit
64 Vacuum Line Control Valve or Circuit
65 Float Chamber Vent COntrol Valve or Circuit
71 Ignition Pulse System
73 Ignition Pulse System
74 Ignition Pulse System
Don't know what it means, or how to fix it, but hope that helps.
