Replacing the ECU yourself is not a problem.
Please don't keep making different posts for the same problem. Just continue on with the original thread.
  babyfacefitz said:
If I replace the ECU, will the car need to go the dealer anyway for something?
Is this a DIY project?
Where can i get an OEM besides the dealer?
michael
  babyfacefitz said:
Thanks for the reply and a note on the "rules". I just called the dealer and they said the ecu would be $1500, is this correct?
Michael
Or, you can send me 200, and I'll get you a tested good one from the junkyard.
1500 bucks is insane...
The local pick-a-part sells ECM's for 35 bucks, WITH a 30 day warranty.
the car is fixed now, the dealer mechanics put it back together correctly.
My frustration levels got to me and I should have stuck with it. I assumed there was more too it, put back in the wire harnesses are simple enough. But what got me was the CEL light. It was one b/c the fuel gauge was not put in at some point and I turned the key. I should have cleared the codes after putting it together myself.
This forum is great. learn from my mistake.
Michael
