dlrallyx'r Posted September 28, 2003 Share Posted September 28, 2003 question for all... taking the trans outta the brat today, all went ok except for the speedo cable, what a good idea to use plastic threaded into aluminum. needless to say that i had to remove the cable from the speedo head to remove trans. So, what, if any, is the trick to removing the speedo cable,as now i not ony have to replace trans (3rd gear failed)but need to replace cable as well. Mike Link to comment Share on other sites More sharing options...
moosens Posted September 28, 2003 Share Posted September 28, 2003 pliers,not the 17mm you probably tried using.THey almost never come off with an open end wrench.I've got one of those cables around too somewhere. Link to comment Share on other sites More sharing options...
asavage Posted September 29, 2003 Share Posted September 29, 2003 Tubing wrench? You can cut a slot from an old box-end wrench in a pinch. But six-point is better. Link to comment Share on other sites More sharing options...
Sweet82 Posted September 29, 2003 Share Posted September 29, 2003 You mean they are suppose to be tight? When I found mine it was undun all by it's self. Wonder how much crap it let into my tranny:mad: Your lucky! Glenn, 82 Hatch, transforming.......:temper: 01 Forester, jealous............ :madder: Link to comment Share on other sites More sharing options...
