peskyjiggler Posted October 25, 2005 Share Posted October 25, 2005 How big of a migraine is it to put a D/R manual trans in a loyale wagon that has a single range manual in it? cheers Pesky Link to comment Share on other sites More sharing options...
TROGDOR! Posted October 25, 2005 Share Posted October 25, 2005 EASY. Swap trans with shifters attached, and get the plastic console piece that snaps in to cover them. As they say in Germany, das ist alles. Link to comment Share on other sites More sharing options...
soobmater Posted October 25, 2005 Share Posted October 25, 2005 yup it should be really easy. Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 26, 2005 Share Posted October 26, 2005 The dual range may be missing the neutral position switch, which will throw a code. Other than that, its plug and play. Link to comment Share on other sites More sharing options...
peskyjiggler Posted October 26, 2005 Author Share Posted October 26, 2005 EASY. Swap trans with shifters attached, and get the plastic console piece that snaps in to cover them. As they say in Germany, das ist alles. That sounds like the equivelent of easy peasy japaneasy...Thanks Pesky Link to comment Share on other sites More sharing options...
Subi81 Posted October 26, 2005 Share Posted October 26, 2005 Did it to my 86, pretty easy just make sure you get the intierior covers with the slot for the 4wd lever and the levers and linkage. And there is the neutral safety switch thing but it doesn't really effect anything. If you are JUST switching the transmission make sure that your rear diff ratio matches the tranny ratio. Good luck Link to comment Share on other sites More sharing options...
